Old 10-05-2014, 04:09 PM   #1
FL71C10
LT-1 in our trucks
I was given a running driving LT-1 engine and 4L60 trans to put into my truck. Yes, I know LS is better, but this is what I have and can afford.
Do I need a high hump?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 10-05-2014, 04:26 PM   #2
Kennuck
Kennuck's Avatar
Re: LT-1 in our trucks
No you don't need a high hump for this combo.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 10-05-2014, 05:40 PM   #3
FL71C10
so the 4L80 is what requires the high hump?
Old 10-05-2014, 06:12 PM   #4
davepl
davepl's Avatar
LT1, not LT-1
4L60E, not 4L60
Does it matter? On the engines, one is externally balanced and the other is internal. On the trans, one is TV cable controlled and the other is PCM controlled. So of course I'm picking nits here, but just in case, helps to be accurate.
If this is out of a post-1992 Impala, Camaro, or Corvette then I assume it's an LT1/4L60E combo.
I'm not an expert on high humps. I always thought it was the TH400 but now I'm not so sure.
Edit: And of course there's yet another LT1 in the current Stringray, but you mentioned a budget so I assume you're not using one of those...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-05-2014, 06:51 PM   #5
FL71C10
Originally Posted by davepl View Post
LT1, not LT-1
4L60E, not 4L60
I didn't realize there was a 4l60 and a 4l60E. I am pretty what I've got is a 4l60E as it is in a 1995 Roadmaster.
Yes, no LT1 from the current stingray. I wish
Old 10-05-2014, 07:51 PM   #6
mechanicalman
So, it's still in a 95 Roadmaster? Does that mean you can take anything off the car you want to?
The LT1s have cool exhaust manifolds, but if you have rams horns I'd use them or headers.
Some cool things you can put on your truck like electric cooling fan/s, sealed cooling system, etc, and if you are tech savvy maybe some other things. You might have to do something creative with the radiator and hoses though.
Roadmaster radiator CORE SIZE 30 5/16IN X 17 3/16IN X 1 5/16IN
Pickup radiator
mechanicalman is offline   Reply With Quote
Old 10-05-2014, 08:08 PM   #7
FL71C10
Yes, I got the whole car. So you think I should use the Roadmaster radiator?
Old 10-05-2014, 10:25 PM   #8
mechanicalman
I don't think it will fit according to the dimensions I found. If you fabricated a mounting system for that and the fans, I think it would get the job done. Do you tow anything larger than a Roadmaster can tow?
It would be nice if you could take all the hoses, lines and everything and make them work but you might have to move the engine around. And the difficulty of moving the engine around depends on what kind of trans linkage you use, if you use column shifter you only have two engine positions, but if you use a cable shifter you can put the engine pretty much where you want it. And you have to consider if the exhaust will clear, etc.
If both the car and truck are still intact, measure from the face of the radiator to the crankshaft dampener face and compare measurements, then determine if you can get it close enough to the same distance.
Notice where the front engine mount brackets bolt to the frame on the truck, you have two sets of holes, and on the driver's side frame rail there is a column shifter bracket that also has two mounting points so you can either go forward or backward.
For the 4l60E you will likely need to get the driveshaft shortened anyway so move the engine first.
Then figure out what is harder, using the Roadmaster radiator or the pickup radiator. Look at the hose inlets/outlet sizes/locations. You going to have to weigh it out, park them side by side and get out your tape measure.
You might be able to make some coolant pipes and use short sections of hose to make connections or use flex hoses it you can't make stock Roadmaster hoses fit up.
I'll be there are others on this forum who have done it and have better advice than I.
You tow?
Old 10-05-2014, 07:25 PM   #9
Kennuck
Kennuck's Avatar
95 Roadmaster would be the 4L60E last widespread usage of the 4L60 was '92
My 4L60E fits in my low hump cab with lots of room to spare.
I think its the 6L80E's that need the high hump.
1970 Short Wide
Vintage Air
Old 10-07-2014, 06:24 PM   #10
Kennuck
Kennuck's Avatar
There is a wealth of swap info here http://lt1swap.com/index.htm
1970 Short Wide
Vintage Air
Old 10-07-2014, 08:20 PM   #11
hugger6933
Doesn't the pass side have a different mounting pattern for the engine mount on the LT1? I may have to take the blanket off mine to look and see But I remember something about it being strange for a/c compressor clearance.
hugger6933 is offline   Reply With Quote
Old 10-07-2014, 08:21 PM   #12
hugger6933
It is like I almost remember the mount being like it was upside down or something similar to that. Jim
Old 10-07-2014, 10:15 PM   #13
Woodnears
If I remember correctly, the lt1 had two different mount locations. Just flip the passenger side bracket to the forward location. I can get pics if needed
Woodnears is offline   Reply With Quote
Old 10-08-2014, 12:24 AM   #14
FL71C10
Thanks. I will see how things go when I get the motor out of the donor car.
Old 11-06-2014, 09:34 PM   #15
FL71C10
Hey, Woodnears. I could use some pics. I got the motor and transmission out of the donor car and am scrapping it tomorrow. I don't need the Buick motor mounts, right. I'm going to use the 71 truck towers and motor mounts?
Thanks!
Old 11-06-2014, 10:19 PM   #16
Woodnears
Pm me so I can keep track of this. Shoot me your email and I'll send you pics of what I have. I'm in Florida tonight but will be back home tomorrow. I just realized you're in Orlando! Ironic, I've been here all week I could have come helped ya. I'm at he airport marriot is that close to you?
Old 11-06-2014, 10:29 PM   #17
FL71C10
I'll PM you my email address. I'm about 15-20 minutes from the airport depending on traffic.
