Junior Member
Has anyone put a New Venture 4500 5 spd tranny in a 67-72 C-10? What kind of bellhousing do you need? What is needed for the clutch. I plan on putting in a 350 SB out of a 79' Chevy. The tranny donor is a 93 3500, but it has a hydraulic clutch. Any help on this subject would be helpful, THANKS.
Old Chevys never die they are just reborn! Last edited by 67chevytodd; 08-13-2003 at 11:19 PM. |
ttt
68 long fleetside C-10, '74 350, CH465 4-speed, Edelbrock Performer 1406 Carb, Hedman Hedders, 50 Series Flowmasters Mesa, AZ |
52peed
I put in a 5 speed from a 96 1/2 ton truck. This is a 2x4 deal. I put it in my 72 Cheyenne. I can send you some pictures but the issues are really not tough:
*- you have to set up the pedals to accomodate the hydralic clutch master cylinder * - You have to get an automatic crossmember to support the rear of the trans * - you have to poke a hole in the firewall and mount the master cylinder * - you have to consider a high hump floor for the top of the trans and shifter * - you have to have your front drive shaft length adjusted * - you have to figure out how to have a speedo set up as the newer trans are electronic sensed verses gear/cable driven I bought the trans complete with bellhousing, clutch, output for drive shaft, etc. for $650. then another $200+ for driveshaft. I got 5 of the 6 above worked out. Get 20+mpg out of a 350 pushing about 260HP with a 308posi rear, headers, HEI, etc. I do not have a solution for the speedo!!!!!!!!!!!!!!!!! |
I put a NV4500 in my 71 4x4, it all should be the same from the motor to the transmission. I used a GM bellhousing with hydraulic clutch. I think the 4500 has two bolt patterns, so make sure you get the correct bellhousing for the transmission. Advance Adapter also builds a bellhousing that uses the stock mechanical clutch in your pickup. The clutch was quite easy to use, just a little bit of planning to get the clutch master mounted correctly. I can't speak to the other issues Huck mentioned, but what he mentioned sounds like it would be the same for the 4500.
LJ
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" |
