Old 10-07-2014, 01:53 PM   #1
Figuarus
Figuarus's Avatar
Low buck rear lowering and rubbing
guys, I am not a smart man. I can admit that. With that being said, I will say that I can usually figure out things pretty reasonably well.
This is not one of those times.
I lowered the rear end of my truck about 4" using TJ rear coils, and compensated for loaded weight by means of using two air shocks on the rear end. Since doing that, I have encountered rubbing on the inner wheel tubs. I can't seem to get this to stop. I am running 235/75/15's all around.
I know I can make it stop by re installing the stock coils, but I want to know how everyone else manages to deal with tire rubbing?
I don't have pictures (I should have taken some, I just got the truck off the lift in the shop...) but I can take some later to show just how much rub is happening here.
Suggestions?
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 10-07-2014, 02:50 PM   #2
Clyde65
Clyde65's Avatar
Re: Low buck rear lowering and rubbing
did you replace the panhard bar with an adjustable one?
Also what is your backspacing on your wheels?
Can you supply some pix for us to look at?
Good luck!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-07-2014, 03:24 PM   #3
Figuarus
Figuarus's Avatar
Clyde,
The panhard bar is still stock unfortunately. It is, however bent (happened from an accident long ago) I will take some pictures and get some measurements. Wheels are factory backspacing.
2013 Malibu LTZ
Old 10-07-2014, 03:56 PM   #4
Renzo
Your stock panhard bar is most likely your problem. When you lowered it it moved the axle off of center. You need and adjusable one like Clyde65 said.
Renzo is offline   Reply With Quote
Old 10-07-2014, 07:04 PM   #5
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Originally Posted by Figuarus View Post
Clyde,
Some people bend these on purpose to compensate for the lower suspension. If you look at my build thread, I used an adjustable bar and it works great.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-08-2014, 12:41 AM   #6
Figuarus
Figuarus's Avatar
Your build thread says you used a tractor hitch, but where did you source it exactly? I could use something like that!
BTW, that is one BEAUTIFUL truck. It makes me miss my '62
2013 Malibu LTZ
Old 10-08-2014, 09:44 PM   #7
scuderia
scuderia's Avatar
not sure if this is the right length but at least it gives you some place to start..
http://www.steinertractor.com/ABC201...stabilizer-bar
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline   Reply With Quote
Old 10-07-2014, 06:49 PM   #8
Clyde65
Clyde65's Avatar
around $50 from CPP
Clyde65
Rebuild of Clyde
support our troops!
Old 10-08-2014, 08:35 AM   #9
61_FL_Apache
Who Me?
Yes. I got mine from Tractor Supply Co for less than $40. It's not the best looking, but works well.
Steve
2001 Blazer 4D 2WD
Old 10-08-2014, 10:02 AM   #10
firemanjimtfd
firemanjimtfd's Avatar
Here is a panhard bar on a truck not lowered yet I bought. Couldn't figure out why the passenger side tire was rubbing till I saw this. Straightened out and centered rear end back up .
firemanjimtfd is offline   Reply With Quote
Old 10-08-2014, 10:30 AM   #11
Figuarus
Figuarus's Avatar
firemanjimtfd,
Are those progressive coils any good? they look like they're sitting on the stack.
2013 Malibu LTZ
Old 10-08-2014, 10:29 AM   #12
Figuarus
Figuarus's Avatar
wow, that's pretty wild.
Mine's not bent quite that hard, but just has a slight curve to it.
I will take a picture later this morning, once I can put it back on the lift.
2013 Malibu LTZ
Old 10-08-2014, 11:54 AM   #13
VictoriaHardware
VictoriaHardware's Avatar
You should only be rubbing on one side if the panhard bar is the problem
VictoriaHardware is offline   Reply With Quote
Old 10-08-2014, 01:47 PM   #14
Figuarus
Figuarus's Avatar
Ok, got some pics.
Note the panhard bar bend
Some not so clear pics
2013 Malibu LTZ
Old 10-08-2014, 02:12 PM   #15
Figuarus
Figuarus's Avatar
this is the driver side wheel tub where its rubbing
2013 Malibu LTZ
Old 10-08-2014, 02:33 PM   #16
f.monroe
f.monroe's Avatar
Since its the driver side that's rubbing I would say bend the bar a little more. It should pull the rear towards the drivers side enough to stop the rub until you can get an adjustable bar.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 10-08-2014, 02:46 PM   #17
Figuarus
Figuarus's Avatar
Frank
True, but it's also happening on the passenger side. i'm thinking I may also need wheel spacers, just to get that extra clearance...
2013 Malibu LTZ
Old 10-08-2014, 03:08 PM   #18
NEWFISHER
NEWFISHER's Avatar
1990's Camaro sway bar works great in the rear of these trucks too. You are on the right track with the tires being to wide for the use of the weak Jeep springs. If you had a progressive rate spring designed for these trucks, you might get away with the width of the tire and the back half not flopping around? Careful on wheel spacers, you may need to push in some longer studs if you decide to run them.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 10-08-2014, 03:27 PM   #19
Mackie
Mackie's Avatar
What offset are the wheels and is the bed orig? The same rear set up in my lowered 63 fleet with 235/70-15 doesn't come close to rubbing but I have 15x8 truck ralleys
Mackie is offline   Reply With Quote
Old 10-08-2014, 03:34 PM   #20
Figuarus
Figuarus's Avatar
Mackie, I have factory 1964 steel wheels. They are 15x8, and have 235/75R15's on them.
2013 Malibu LTZ
Old 10-08-2014, 08:33 PM   #21
PGSigns
PGSigns's Avatar
Lay on the ground and get some one to shove the truck side to side and see if anything moves. If the panhard bar bushings or the trailing arm bushings are shot you can get some extra movement. Also look at what part of the tire is rubbing on the wheel well. You may find it is happening when you pull into a step driveway an one tire goes up and the other goes down.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-08-2014, 09:13 PM   #22
NurseBen
NurseBen's Avatar
I have a '69 but should be the same. Running 30 X 12 X 15 on wheel vintiques, I think the rims are 10 inches with 4.5 of back spacing. The only time it rubs is with my 250 pound neighbor in the passenger seat
NurseBen is offline   Reply With Quote
Old 10-10-2014, 11:47 AM   #23
Figuarus
Figuarus's Avatar
PGSigns, I had my wife rock the bed, and sure enough, the track arm bushings have movement. I am going to pump the air shocks a little more and ride a little higher than I'd like.
i'm gonna find that track arm, and get it centered. hopefully, that's all that's the problem.
thanks everyone!
2013 Malibu LTZ
Old 10-12-2014, 01:33 AM   #24
Figuarus
Figuarus's Avatar
Well, adding some Timbrens from my S10 helped. I will have to trim them, but there is a vast improvement
2013 Malibu LTZ
Old 10-13-2014, 11:05 AM   #25
Mackie
Mackie's Avatar
I don't know what Timbrens are but it looks like rubber bump stops that we're not there before.
