Old 10-08-2014, 01:51 PM   #1
ACII
bad quality aftermarket fuel rails, what can i do ?
Hy all
finally i got my new set of fuel rails for doing a return fuel setup.
After i have checked the rails i found out that there are some small blades inside of the center whole...
For details pls check the pics...
I am from Germany so its not easy to send it back, therefore i hope u know any solution for smoothing the rail at the inside of the center whole..
Thanks a lot
Achim
ACII is offline   Reply With Quote
Old 10-08-2014, 06:40 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: bad quality aftermarket fuel rails, what can i do ?
not sure what you are seeing. can you clean it out with a wire brush or something?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-08-2014, 08:57 PM   #3
truckdude239
truckdude239's Avatar
You can have a machine shop chase the treads and clean the burrs and clean the sides
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 10-09-2014, 03:07 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Ya it just looks like some burs on the machining in the aluminum.
You can have a machine shop or mechanic shop chase the thread, or get the correct size tap-and-die (thread chaser) and do it yourself. Shouldn't be a big deal.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-09-2014, 08:21 AM   #5
Clyde65
Clyde65's Avatar
also an Emory cloth would help for delicate deburring also.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
