Old 10-08-2014, 02:52 PM   #1
rusted72'
rusted72''s Avatar
1972 Correct Fuel Pump?
Wondering If I have the correct fuel pump on my 72 c10 with a 350 and an automatic tranny. I purchased a hard fuel line which goes from pump to carburetor but it will only fit the smaller pumps with 2 lines. the longer pump has 3 lines and the hard line outlet for this type is facing the engine unlike the 2 line pump which faces the radiator. Is there a different hard fuel line for the 3 line fuel pump.
If i change pump to a 2 line everything will fit except I now have a return line or vent line dangling.
what can be done to fix this?
any suggestions?
thanks
rusted72' is offline   Reply With Quote
Old 10-08-2014, 06:29 PM   #2
NCBowtie
Re: 1972 Correct Fuel Pump?
Bttt
NCBowtie is offline   Reply With Quote
Old 10-08-2014, 11:06 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Here's another bump.
The fuel pump looks to be a replacement. No telling what year was ordered but the size of the fitting is for either a 3/8 or 5/16 fuel line. Easiest thing to do is to get a fitting that can either reduce or increase the size of the line connector.
If you want to be more correct, I would contact the local vendors on this site and ask them for help in getting the correct parts.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
