10-12-2014, 09:03 PM | #1 |
'67 c-10 washer switch
i replaced my washer/wiper switch, stock washer pump and hoses. I got it all working, but now the washers come on everytime i turn the wipers on. i know to use the washers, you push the switch in while turning the wipers on and to use the wipers only, you turn the switch without pushing it in. no matter how i use the switch, the washers still come on.
Any help in fixing it would be appreciate it! |
10-12-2014, 09:08 PM | #2 |
Re: '67 c-10 washer switch
The motor is switched ground, so I'll presume the pump is too (easy to reverse the test if its not). Get a test light or DVM and see what you find at the pump wires before and while you turn the washers (only) on. If it powers the motor on the connectors, your switch is bad.
Be sure to check both sides of the circuit (power side and ground). At least one should change when you hit the washer switch. If its the same before and after, it's the switch. If you replaced the switch, don't you have the old one around to just plug it into the harness (and ground the switch) to test it? I believe the pump and motor are separate enough that I can't picture a short from one to the other causing the pump to run. If someone can come up with a scenario where it could happen, please throw it in here so he has the full range of possibilities.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
10-12-2014, 09:30 PM | #3 |
Also 67 switch is a little different than 68 and up, the portion that sticks through the dash is actually longer so it may be tough to find a new switch, as it is a one year piece.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
10-12-2014, 09:44 PM | #4 |
More out of curiosity, but does the 67 switch automatically turn on the wipers when you push in for washers?
10-12-2014, 10:39 PM | #5 |
Dave: yes it does. 71 super: the new switch is a little longer than the light switch below. Although the old wiper switch wasnt? Makes me wonder if the old one was from a different year? Unfortunately I trashed the old switch. Thanx for the advice!
Tags |
wiper/washer switch |
