10-13-2014, 12:03 PM | #1 |
Porterbuilt plans
Do we get a fourm member discount? ALso anyone used their stock control arms? Says you can (ive already dumped a bunch in moog parts). If using your stock arms does it still lay frame?
10-13-2014, 04:10 PM | #2 | |
Re: Porterbuilt plans
Stock uppers will work from 63-87 C10... may need a little trimming of the stamped steel around the bushing ends (mainly on the 73-87 frame). Lowers from 73-87 C10 will work on the Level 3 (Extreme) Version 5. Must remove the factory cross-shaft and may need a little trimming on the bushings. May or may not lay frame... depends on tire size, and spindle. Be prepared to recess the bag into the factory arm if running large diameter rubber. If you have more questions feel free to shoot us an email at sales@pbfab.com. Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
10-13-2014, 06:29 PM | #3 |
29" tall tire ... 15" white walls .... thanks for the reply
