Old 10-15-2014, 09:37 AM   #1
85chevy86
Squealing kind of noise
I put a new 350 in me truck last month and finally got to drive it around. Well I drove it on two short trips and all was good. When I went to drive it the third time I was getting a loud squealing type noise but only under accelerating. I checked the headers and the driver side one was lose I tighten it up but it still makes the noise but I don’t think it is as loud now. I got new gaskets on the way to work thinking I may have blown that one out. Is there anything else I should check if that is not it?
I also read that it could be the speedo cable. I did not think about looking at that when I was driving but I do know it use to bounce a little around 20-30 mph.
The 350 has a bigger cam, roller rockers, and Pete Jackson gears. Its in a 1986c-10
Evan
85chevy86 is offline   Reply With Quote
Old 10-15-2014, 11:22 AM   #2
77 350 Shorty Wide
77 350 Shorty Wide's Avatar
Re: Squealing kind of noise
Good Morning,
You may have answered your own question. A geared timing setup can make quite a bit of noise especially if your unfamiliar with their sound.
Also check your belts. Rub a little soap on the top while the engine is running.
Have a Great Glorious Day! Terry
77 350 Shorty Wide is offline   Reply With Quote
Old 10-15-2014, 11:52 AM   #3
85chevy86
I though about the gears also but it seems like a higher pitch sound. The first few starts the starter was acting like it was hanging up a little so I am going to check that after work also.
thanks Evan
Old 10-15-2014, 12:05 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
A loose power steering belt can squeal so can a water pump bearing,may want to check those
water pumps can stop squealing after a engine start.
sometimes a broom stick moved from each part to ear can narrow it down
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 10-15-2014, 12:41 PM   #5
85chevy86
Thanks Motornut I will try the broom stick thing. I hope it is not the water pump it is a new team G water pump the guy put on be for he sold me the motor.
Old 10-20-2014, 01:40 PM   #6
85chevy86
I found the sound. I feel kind of dumb. I did not know a flex plate really flexed. When I put on my mini starter I did not measure it just seen that it was not touching. I guess when I hit the gas it was close enough to touch. Shimmed the starter and all is good.
Thanks again
Evan
Old 10-21-2014, 02:10 PM   #7
xrcr
Doing Dumb stuff is one way to learn, just learn from it. If not people will think you're stupid. Don't ask how I know....
xrcr is offline   Reply With Quote
Old 10-21-2014, 03:57 PM   #8
85chevy86
I really did not want to put what it was but I figured it may help someone else.
Old 10-21-2014, 04:26 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
I had to remove them on mine PO put in to fix the mashing of gear teeth,when i got it
I removed it,and replaced the flex-plate,its better now
on the truck it was hard to tell,but compared to the old one...
it's mentioned the gap is as little as a paper clip,when properly meshed
John
