Universal Power Window Kit
Saw this on amazon today. Really, really cheap. Has anyone installed something like this on their truck?
![]() Join Date: Jun 2005
Re: Universal Power Window Kit
Don't know about that brand, but the cable driven ones are not powerful enough to raise the window if the division bar channel is worn.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
My windows roll up and down with little effort. Would that make a difference?
Probably. You can make your own out of stock regulators. Search for "power windows on the cheap" in the box at the top of the page. Be sure to click on the 67-72 dot first.
I just put a set of these Electric Life PW regulators in my sons 71 GMC. It's an easy install and they work great. http://electric-life.com/shopexd.asp?id=926
"Negative people always seem to have a problem for every solution" |
Those cable ones still drive the factory window crankshaft, so I guess they must stick out of the door somehow (since the shaft itself does). Unless they have you cut it off. I'd like to see a picture of this style installed.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
I have used these on two streetrod builds and they work great. Real easy to install .
#8 | |
and the part that goes over the splined regulator shaft. I had the passenger side installed, but it would not raise the window without help. Member bonnieclyde100 made power regulators from his stock ones. He has a youtube video on it. Only cost would be the motors and wiring/switches. I did mine patterned after his and they work great.
X2 on the Electric Life kit. Really strong motors and no faffing around with "custom" mounts, etc. Even possible to keep the stock cranks. I've had my kit installed for about a year now and the motors are still really fast. Wired in for remote fob control is cool too.
![]() Here's the full story on the install on my '68... http://www.customclassictrucks.com/t..._installation/ Hope this helps! |
