Need bearing advice
My project just keeps going.....starting with a front end rebuild has now sprouted into wheel bearings.
I have a C20 1969 with a 5.7L. My preference is Timken bearings but have been striking out on finding stock for the inner bearing and race. What are your opinions on other brands like National, SKF and AST? Any suggestions on sources? |
Re: Need bearing advice
I would just take the old bearings with you down to O'reilly's and they can put their caliper on it and find out the I.D and O.D and go get some made in the usa bearings off the shelf, or if they don't have them in stock they can order them and usually get them in the same day as long as you order first thing in the morning.
The National Bearings are fine for most people. I too prefer Timken over National and the others but at the end of the day I will use National. Its cost effective and conical bearings rarely just randomly give it up without some kind tell tale grindey/crunchy sounds before they die(IMO). The National parts are off the shelf stuff, A-3s for the outer and 2777s for the inners. Should be able to get them any where.
88Ironduke
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!! ![]() My Build Thread: Project 72' Green http://67-72chevytrucks.com/vboard/s...d.php?t=587932 |
Inner race Timken 382 on eBay
http://www.ebay.com/itm/Timken-382-W...0299d4&vxp=mtr Inner bearing Timken 388A on eBay http://www.ebay.com/itm/Wheel-Bearin...827a57&vxp=mtr
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
#5 | |
Check the dimensions of your bearing with a vernier caliper and compare to those below just to be sure. Part numbers have a habit of changing after 47 years or so. Timken B45 Dimensions are: Inside Diameter : 23.03 mm,0.9065 in Outside Diameter : 57.16 mm,2.2503 in Radius : 0 mm,0 in Width : 20.07 mm,0.79 in Model: 909545+909725+909625 Classes: BALL BEARING Details: SINGLE ROW, Other Details: FRONT WHEEL COMPLETE |
Just FYI, never spin up a roller bearing in your hand with compressed air. Local guy lost some fingers not that long ago.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#8 | |
How on earth (and where) did that happen?
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
How funny you mention the warning about spinning a dry bearing with compressed air. I just read an article from Timken about the dangers of a bearing coming apart under that same scenario.
![]() Join Date: Mar 2012
i always thought that the NAPA premium brand bearings where re-boxed timkens????
and Auto zone carries timkens I think you need the set 3 and set 4
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
