10-17-2014, 09:42 AM | #1 |
cab differences?
Is there any difference between a 67-72 cab itself? Besides a small window 67?
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
10-17-2014, 10:28 AM | #2 |
Re: cab differences?
The hole in the fire wall is different for 67-68 harnesses. Also the mounts are different for the parking brake and the gas pedal.
1967custom |
10-17-2014, 10:41 AM | #3 |
Yes there are differences between the cabs, but the body lines are all the same, so any 67-72 cab can be use with any other 67-72 body or frame, but you may need to make some mods for everything to work.
* 72 cabs the rear view mirror is on the windshield, and no boss on the roof for the mirror. * 71-72 have a vent in the DS door pillar and the vin tag is mounted higher. They also have a cable for the throttle so there are differences to do with that. * 71 cabs have a boss on the roof for the rear view mirror. * 67-maybe 68 have a different size hole for the fuse block, and different hole for the throttle rod set up. * A/C vs non A/C cabs are different. * 67 and some 68 small rear window. * High floor hump vs low. I'm sure there’s more that other people will mention, but any of these cabs can work ! Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
10-17-2014, 11:05 AM | #4 |
Thanks guys. I've been offered my choice of 3 cabs, the original 68, a 72 and a 70. Forgot about the mirror. Hmm could do the 72 with earlier doors and mess with people that know the differences lol
10-17-2014, 11:20 AM | #5 |
The general public would never know the difference, but there's guys on here that could tell every little detail !!!! "LOL"
If your truck is a 68, and the 68 cab is in good shape, that would be my choice ! Gary
10-17-2014, 11:39 AM | #6 |
There's a 71 that runs around here with a 67 small window cab lol it annoys me every time I see it lol
10-17-2014, 11:50 AM | #7 |
Yeah that would bug me. Heck if I see a 72 and the mirror is on the roof I know the cab has been swapped. "LOL"
10-17-2014, 06:22 PM | #8 |
10-17-2014, 12:29 PM | #9 |
69-72 have a cargo light.
Keep in mind that some states require the Vin plate on the cab to match the numbers on the frame so you need to call the DMV and find out what the regulations are. |
10-17-2014, 12:57 PM | #10 |
Yup... What Xeen said..... Check with the DMV, every state is different....
10-17-2014, 06:36 PM | #11 |
Hmm shaved marker lights, 72 cab, 69-70 door panels. I could mess with some people
10-17-2014, 08:56 PM | #12 |
Well I have a one ton cab that I want to put on a 70 C20 ? Will there be issues? I have cab lights on the top of the one ton, think it may have come from a tow truck.
10-17-2014, 09:32 PM | #13 |
Shouldn't be. Unless ones an ac cab and one isn't.
10-17-2014, 09:32 PM | #14 |
Wait one ton as in c30 or heavy hauler type stuff?
10-18-2014, 08:06 AM | #15 |
A C30 cab should work fine !
10-19-2014, 12:17 AM | #16 |
