Old 10-20-2014, 02:01 AM   #1
87Skier
87Skier's Avatar
Fuel Filler Neck rusted out
Well, sad day. I was going to put in my new gas tank but thought I better check out my filler neck since it had some other rusty pieces around it and sure enough, discovered a large hole right where it meets the floor and has the gasket around it.
So, other than buying a used one from the forum, what are my options? Is it possible to clean it up and weld a new section on? What have you guys done in the passed?
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 10-20-2014, 12:36 PM   #2
jaros44sr
jaros44sr's Avatar
Re: Fuel Filler Neck rusted out
Normally, i would say go for the fix, but, that area has a reduced shoulder at the bend....could be difficult and time consuming to weld or solder
Since these parts are accessible in the parts forum, JMHO, but it may be an easier fix to buy a used one.....unusual place for rust to appear, never seen that before. I guess the gasket held water
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-20-2014, 01:25 PM   #3
87Skier
87Skier's Avatar
I'm not surprised that it was rusted out. I'm thinking if I do attempt to fix it, I'll cut it way back to near the top, and weld on from there, but I will try to locate one before I attempt it
Old 10-20-2014, 02:11 PM   #4
jaros44sr
jaros44sr's Avatar
Well, good luck with whatever direction you take....i ll keep an eye out for you on the classified. I suppose you could get a mandrel bent 90
Korinek or tee it up, would be a good place to start. If i had one, i d ship it to you
Nice looking Jimmy
SAFETY FIRST
AS usual, off topic
Jim
Old 10-22-2014, 10:47 PM   #5
87Skier
87Skier's Avatar
Originally Posted by jaros44sr View Post
Nice looking Jimmy
Old 10-23-2014, 08:02 AM   #6
67Steven
67Steven's Avatar
Since you're relatively near-by in Corvallis, i can bend a 1.25" tube 90* and give it to you. Or I could weld it in if you need. I probably have some in the cut pile.
Just another option.
1972 Blazer build: http://67-72chevytrucks.com/vboard/s...d.php?t=615744
67Steven is offline   Reply With Quote
Old 10-20-2014, 09:10 PM   #7
1rippen6
87 Skier sent you a pm
1rippen6 is offline   Reply With Quote
