Old 10-20-2014, 03:23 PM   #1
bevos68bowtie
Thinking about switching to elec radiator fan.
I read a forum on here that early 90's Ford Taurus fans are a good one to use on our trucks. Any comments?
67 C10 step side 355ci
05 Z71 reg cab short fleet side
bevos68bowtie is offline   Reply With Quote
Old 10-20-2014, 03:35 PM   #2
Sammy
Re: Thinking about switching to elec radiator fan.
Jeep are popular, Lincoln several threads on conversions. Wiring n relays will be needed also.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 10-20-2014, 04:11 PM   #3
BC10
BC10's Avatar
Why the switch, if you don't mind me asking?
I use to have an electric one, but switched back to mechanical when I started having electrical issues, I hate dealing with relays.
BC10 is offline   Reply With Quote
Old 10-20-2014, 04:20 PM   #4
bevos68bowtie
I've heard it gives a lot more horsepower and better cooling. And my fan won't fit in my shroud.
Old 10-20-2014, 04:29 PM   #5
bevos68bowtie
We have hot summers here and I am worried about overheating. But I don't won't anymore electrical problems either. I already have a battery draw that I can't figure out. I appreicate everyone's input!
Old 10-20-2014, 04:59 PM   #6
davepl
davepl's Avatar
Factory clutch fans at speed don't take much power - something like 3hp. A fixed fan takes a lot more.
Why not get the right shroud for your truck and be done with it? Hell of a lot better than driving around with Taurus fans on a switch. Plus it doesn't sound like your electrical system is currently up to the task of running a 30 amp fan or whatever it is.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-20-2014, 04:42 PM   #7
Sammy
If you start adding stuff power windows, huge draw amp, clock, air compressors, headlights, n air you actually tax your electrical system pretty hard for our stock alternators. I personally think it is a worthy upgrade for the fans. But maybe not to everyone's taste.
Old 10-20-2014, 04:57 PM   #8
BC10
BC10's Avatar
There are some great topics on this.
http://67-72chevytrucks.com/vboard/s...d.php?t=585573
I bought an aftermarket shroud and an oem fan, runs smooth and cool with no problems. You can't go wrong with either one. But I would definitely take care of that electrical issue first.
Old 10-20-2014, 05:44 PM   #9
48richard
48richard's Avatar
I was overheating on long grades in 110 + temperatures. Because I had radiator leaks I installed a new 4-row radiator from Autozone (less than $100), and since then my temperature gauge sits at the thermostat point in any temperature Phoenix can throw at me, using the stock clutch fan and shroud.
If it ain't broke, don't fix it, in my opinion.
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 10-20-2014, 05:53 PM   #10
67JimmyMO
67JimmyMO's Avatar
Originally Posted by 48richard View Post
I installed a new 4-row radiator from Autozone (less than $100)...
Do you have a part number for that rad? Thanks.
Still running the stock 6 cyl. rad in mine, with a clutch fan and electric backup. Does ok on cool days but think I will need more rad when it gets hot outside again.
1967 GMC SWB 383 Stroker w/Saginaw 4sp
1979 Chev C30 Scottsdale Flatbed 350 4sp
2000 Chev 3500 Flatbed 454 Automatic
1978 GMC 6500 Flatbed Dump 366 5sp + 2sp
1965 Chev K10 LWB 230 4sp
1985 Chev K30 Flatbed 350 4sp
67JimmyMO is offline   Reply With Quote
Old 10-20-2014, 09:12 PM   #11
bevos68bowtie
sorry
Old 10-20-2014, 10:56 PM   #12
48richard
48richard's Avatar
Sorry, no I don't, and when I looked at the Autozone website the only one they show now is $186. The one I got was copper/brass, and looks just like the OEM part.
It was 3 or 4 years ago, and my point was not to promote any particular radiator, but to say that the stock cooling system works just fine in my truck in a severe climate.
