Old 10-21-2014, 01:33 PM   #1
'65 chevy lover
Removing side trim from 65 chevy pickup
How do you remove the side trim from 65 C10 chevy truck? Trying to get everything removed so I can take pics to sell. Thanks for any help.
Edit: I did a search before my post but, didn't find anything about removal of side trim.
Bump...anyone?
'65 chevy lover is offline   Reply With Quote
Old 10-21-2014, 09:45 PM   #2
joedoh
joedoh's Avatar
Re: Removing side trim from 65 chevy pickup
its just clipped into holes drilled in the side sheetmetal so you can get a putty knife behind it and feel for the spring clip and pop pop pop all the way down.
except
the 4 cab pieces are attached from inside the cab, you cant pop those off unless you like bent pieces. Its why trim sets sell without those pieces because once guys bend them they are junk. use extra care removing the 4 small cab pieces behind the door.
Old 10-21-2014, 10:54 PM   #3
'65 chevy lover
except
Thank you very much for the reply!
Old 10-21-2014, 10:02 PM   #4
j.rigby15r
j.rigby15r's Avatar
Thank you for asking that question. Once you get them off let me know if you need a buyer. I need a set for my 64.
j.rigby15r is offline   Reply With Quote
Old 10-21-2014, 11:05 PM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
fenders are bolted on, (the clips) the bed has the plastic clips, which will probably break as you take them off, might double check your doors, can't remember if they were plastic, or bolted.
Old 10-21-2014, 11:10 PM   #6
'65 chevy lover
Thanks alot for the reply, much appreciated!
