10-23-2014, 10:37 AM | #1 |
Never Ending Projects
3M molding tape to install rear door seals?
Hi all,
I have new seals for the rear doors on the panel. These are to be glued on, which can be a PITA and messy. I was thinking about the 3M molding tape. This is the thin stuff used on late model cars/trucks to hold trim moldings on the side of the vehicle. I was thinking I could apply the tape to the door and then stick the rubber seals to that. It would make for a clean and simple install and having tried to removed this stuff before, it seems to stick really well. Has anyone else ever tried this method?
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
10-27-2014, 06:24 PM | #2 |
Re: 3M molding tape to install rear door seals?
So I take it, no one has tried this...
10-27-2014, 11:29 PM | #3 |
I have never tried this but it looks like 3M tape is on the Steele rubber peel n stick products.
http://www.steelerubber.com/peel-n-stick-extrusions I would try a test piece, let it sit for a few days then pull it apart to see what fails first. I hope this helps |
10-28-2014, 10:56 AM | #4 |
Cool, good call. Didn't know they offered those.
10-29-2014, 10:18 AM | #5 |
The seals should insert in the hinge hole and stay without glue. So why are you using glue, I must of missed something.
10-29-2014, 10:44 AM | #6 |
I think you are talking about the external hinge seal. I am talking about the seal that goes around the whole door, that seals to the body. These are normally glued on and I want to do it with less mess and hassle, hence trying to use the tape.
10-29-2014, 11:50 AM | #7 |
ok, I misunderstood your question. I was talking about the hinge seals.
