Old 10-23-2014, 10:51 AM   #1
65truckowner
65truckowner's Avatar
66 manual steering box seals
I am needing to put new seals in my manual steering box on my 66 chevy c10. Does anybody know where to get the seals? I have checked my local part store and lmc and classic truck with no luck.
65truckowner is offline   Reply With Quote
Old 10-23-2014, 08:33 PM   #2
65truckowner
Re: 66 manual steering box seals
Has no body resealed there manual steering box??
Old 10-24-2014, 12:09 AM   #3
66Submarine
66Submarine's Avatar
Rockauto has them listed: National #480821 for the worm shaft and National #313842 for the pitman shaft.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 10-24-2014, 07:38 AM   #4
65truckowner
Thanks that will help a lot. I noticed you have a 68 impala. I have a 67 impala ss. It runs but needs restored. It was my dads car he bought it in 1970
Old 10-24-2014, 05:15 PM   #5
x1buellist
x1buellist's Avatar
I bought the worm gear and pitman shaft seals from classicparts. I bought the shims off of ebay. BTW , I used Penrite steering box lube.
x1buellist is offline   Reply With Quote
Old 10-24-2014, 05:30 PM   #6
66Submarine
Neat; I like the '67's.
Old 10-24-2014, 05:54 PM   #7
NEWFISHER
NEWFISHER's Avatar
If you pick up the frame bracket from captain Fab and get a 2x 71 and up box, lines and adapt a pump to your engine, it takes a Saturday to have pinky finger powersteering. I was a skeptic until I converted mine. Now I am gathering parts for every rig to convert them!
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 10-24-2014, 07:57 PM   #8
65truckowner
I put that set up on my last truck I built. I used the complete front end from a 83 model. If I installed the power steering box on my 66 which tie rods would I have to change?
Old 10-26-2014, 12:49 AM   #9
Captainfab
60-66 Nut
If you are keeping drums up front, you don't need to change anything. Just attach the power steering pitman arm to your original draglink. If you are changing to front discs, change the entire steering linkage to the '73-'87 components. You will just have to drill 2 new holes for the later model idler arm.
