Old 10-23-2014, 02:43 PM   #1
cheyenne shortstep
cheyenne shortstep's Avatar
Sub, rear A.C. hose routing
Mario72 asked for these pics and I thought they might be helpful to anyone else doing a rear A.C. conversion so here they are. First pic is where they enter the cab below the dead door [driver side inner rocker], second is from inside the dead door to rear 1/4 panel and third is where they exit the roof/rear pillar to connect to the fan/blower unit.
cheyenne shortstep is offline   Reply With Quote
Old 10-23-2014, 07:03 PM   #2
72MARIO
72MARIO's Avatar
Re: Sub, rear A.C. hose routing
Thanks for posting the pictures. I will get the money out to you this weekend.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-17-2015, 10:06 PM   #3
72MARIO
72MARIO's Avatar
Ttt for hose routing in a suburban
2005 TAHOE DD
Old 03-18-2015, 08:27 AM   #4
highwinger
highwinger's Avatar
here's the overall routing
highwinger is offline   Reply With Quote
Old 03-18-2015, 08:51 AM   #5
72MARIO
72MARIO's Avatar
I would still like to see where the lines cross under the truck. Are the lines run on top of the trailing arm cross member ?
2005 TAHOE DD
Old 03-18-2015, 10:14 AM   #6
cheyenne shortstep
Mario, I will take some pics of the hose routing for you. I still have both 72 'Burbs w/ rear A.C. in my yard and both are trailing arm.
Old 03-25-2015, 09:51 AM   #7
Gobuffalo
Gobuffalo's Avatar
This is a 70 Suburban 4x4.
You can see the 3 original clamps that hold the hoses to the bottom of the floor.
Gobuffalo is offline   Reply With Quote
Old 03-25-2015, 01:03 PM   #8
Bigdav160
Bigdav160's Avatar
2WD Suburban? My 4WD is slightly different. The hoses take a more right angle approach across the bottom above the transfer case.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-25-2015, 04:30 PM   #9
RedRoad
RedRoad's Avatar
Originally Posted by bigdav160 View Post
2wd suburban? My 4wd is slightly different. The hoses take a more right angle approach across the bottom above the transfer case.
x2
RedRoad is offline   Reply With Quote
