10-26-2014, 12:29 AM | #1 |
What's behind your seat..?
Hi all!
The following is a thread that I made on another 73-87 truck forum here: http://forum.73-87chevytrucks.com/sm...6515#msg246515 (Check out the CUCV M1028) I'm still looking for some inspiration. Saw a nice custom wood shelving mod by poster "tucsonjwt" here: http://67-72chevytrucks.com/vboard/s...4&postcount=30 tucsonjwt, did you follow a template for that? ----------- Looking for ideas for organizing the area of the cab behind the seat. Looking for your input on what to have, how to store/install it. Anyone seen a truck of our kind that has been used in a military/police/security/fire capacity? I'd imagine they'd have a sturdy setup for equipment. Rough Ideas: Items: Flash Light Fire Extinguisher Firearm Med Kit Trash Container Tools Ice-Scraper/Squeegee Oil/Trans Fluid Interior Body: OEM Panelboard (what I have now) Caged/Custom Mods: 12V Cig Socket USB Power Socket Custom wired holster for LED FL charging Rifle Rack FE bracket Small Safe So, what's behind your seat? What's your setup? Any pics? Where do things attach, weld, wire or screw into, and what's the proper way of going about it? ----------- Mine (Panelboard not in at the moment): Sincerely, IdahoMan |
10-26-2014, 08:18 AM | #2 |
BAD BOW-Silverado XST
Re: What's behind your seat..?
One big box with two 12" competiton woofers. Both powered by a nice stainless steel amp. Eardrum busters even with the windows rolled down!
10-26-2014, 10:28 AM | #3 |
HiLift Jack, heavy down jacket, 4-way lug wrench.
10-26-2014, 11:46 AM | #4 |
"DON'T TOUCH THE TRIM!!"-Early Kyler |
10-26-2014, 01:37 PM | #5 |
'86 Chevy K10 SWB Custom Deluxe 4x4 '94 Chevy Corvette '07 Ford Mustang '08 Lexus LS 460 |
10-26-2014, 10:25 PM | #6 |
'82 C-10 SWB / C'd, Z'd, Body'd and Bagged / Shaved firewall, wiper cowl, drip rails, stake holes and tailgate/ 20" & 22" Milanni Voodoo '81 C-10 SWB Parts Truck IRC - http://webchat.snoonet.org/#baggedtrucks |
10-26-2014, 10:31 PM | #7 |
...just another truck junkie..
The way my adventure has been going probably another huge mouse nest and more poop and urine! I'll find out for certain tomorrow night.
Mike "Bear" Shea |
10-27-2014, 01:00 AM | #8 |
No template - just measured with the seat all the way back - so no rubbing anywhere. I used 3 self tapping sheet metal screws in the lip under the window in the vertical recess spaces so the short screws would not penetrate the back wall of the cap - plenty secure. The custom cab corner speaker boxes were also very handy and no cost to build using scraps I had available.
My best advice - lay out everything you want to store and then design a storage bin to accommodate each item. Store most frequently used items on top and outer cubbies. This is basically just a big open front triangle with a 1/4" plywood back and 1Xs and other plywood pieces for the shelves and dividers. If might be a good idea to just use cheap plywood or MDF or even OSB if you are undecided on what you want so you don't waste expensive stock. Actually, nobody will see it back there so cheap stock is probably the most practical option. |
10-27-2014, 11:07 AM | #9 |
Some recent pics with storage utilization.
10-27-2014, 12:05 PM | #10 |
Bought this behind the seat shelf setup many years ago. I think it is a Rubbermaid product. Found it at Pepboys. Cut some carpet pieces to line the bottoms of the shelf areas to cut down on rattles.
10-27-2014, 02:42 PM | #11 |
Dee Zee Inc. #CO75 around $90.
RIZ |
10-27-2014, 03:46 PM | #12 | |
Is that a Halon 1211 Extinguisher you have there? I'm thinking of getting one fo those. IM |
10-27-2014, 03:15 PM | #13 |
Active Member
thanks just ordered that.
11-11-2014, 06:13 PM | #14 |
This is the best one I've seen. It's more speaker-oriented, but the concept can be adapted to anything. If this was his first attempt at fiberglass, maybe results like this really are attainable by the average Joe.
http://67-72chevytrucks.com/vboard/s...ght=fiberglass
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
11-12-2014, 08:59 AM | #15 |
Don't Crush em Restore em
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually |
Tags |
seat, storage |
