![]() Join Date: Feb 2011
Question about CHEVROLET hood letters
I need help! The only outside emblem, I left was the CHEVROLET Letter on the hood. Unfortunately the holes seem smaller or missing do to possible bondo and body work. Can anyone give me any pointers or a template to ensure correct placement on the letters. I know I may have to put tape on the holes and re drill them. The question I have, does all the letters come with 2 holes? I searched the forum, but no luck...
http://67-72chevytrucks.com/vboard/s...ban+Retro:fro: |
#2 | |
Re: Question about CHEVROLET hood letters
Like you said use tape, and I'd put it on before grinding bondo and be careful not to make a lot of heat ![]() |
Sorry for not being more clear. The truck is actually painted now. I'm trying not to ruin my paint. You can see the holes but the pegs don't fit in them and some seem to have two holes for each letter and others only show one hole for each letter which is strange because all the letters have 2 pegs.
http://67-72chevytrucks.com/vboard/s...ban+Retro:fro: Last edited by Orangetonicclicc; 10-27-2014 at 07:11 PM. Reason: Wording |
![]() Join Date: May 2010
Normally, the assembly manual shows emblem and molding locations and hole spacing. Unfortunately, I don't have mine here to check. Perhaps someone can check and post a picture for you.
In the meantime check post 12 here: http://67-72chevytrucks.com/vboard/s...d.php?t=329097 EDIT: OK, I admit I am not familiar with the letters, but the pictures in the old for sale thread below seem to show only one stud per letter that take a speed nut. The other studs seem to be smaller and only serve to keep the letters properly positioned. http://67-72chevytrucks.com/vboard/s...d.php?t=630231 Last edited by FirstOwner69; 10-27-2014 at 07:43 PM. |
#5 | |
Two holes per letter, one is alignment post the other accepts a speed nut. The large hole is always on the left, small on the right. A quick check with my calipers on an original hood with one re-spray I got .150" for the large and .130" for the small. Here's the hood I checked.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car Last edited by 67c10rustbuket; 10-27-2014 at 07:52 PM. Reason: Fat finger auto correct grrrr |
#7 | |
Could you make me a template? Lined to the bottom of the hood and send it to me? I'd pay for the postage.
Gotta get kids in bed, talk in a while.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
Your best bet is to access the holes from the back of the hood
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly ![]() |
![]() Join Date: Oct 2009
Are you getting a template? I have a hood with the letters off. Might can help you with that if you cant get that from someone else. Good luck.
A guy said he would send me one. I'm sure he will. Maybe just got side tracked. If he doesn't, I will be sure to take you up on your offer! Thanks a lot!
I saw on your build that BOOSTED said he would make a template so I figured you were taken care of. If you still need I can make something up this weekend. Let us know if you get, or still need something. Later
#14 | |
Thanks!
#15 |
Cool, I will plan on making a template this weekend. I will let you know
#16 |
A bit slow and somewhat hyper anal...... here is what I have accomplished so far. This is much more involved than it seems.
First step, I measured the angle of the hood lip and sheared a couple pieces of steel and formed a short flange to hold the distance from the lip of the hood. ![]() I clamped two pieces in place and started marking holes with a scribe. ![]() ![]() ![]() ![]() I then scribed a line on the hood just to get a visual of how/if the holes were in line with each other. You can see here that the O L E and T screw stud hole are all aligned. easy peezy ![]() BUT... the C H E V R are not, why make it easy.... (Note, if you are like me and leave your pristine hood outside in windy Oklahoma the tip will end up damaged like this one...) ![]() SO here we are all marked up for the mounting stud holes. Now I will take these to work Monday and punch the holes then mount to the hood with machine screws. I will then have to use an angled scribe to mark the alignment pin holes since they do not have an access hole like the mounting stud. ![]()
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car Last edited by 67c10rustbuket; 11-07-2014 at 09:57 PM. Reason: add |
#17 |
Wow bro! I figured you just take some sheet of paper and make the marks lined on the angle of the nose. I had no idea you would get that detailed. I gotta give you something for your time and effort.
#18 |
No prob. I finished these templates and since I see you have at least the "R" you can use those holes and the hood edge to mark the rest. The only catch is I need you to send these back so I can make a one piece template from them. Just PM me a name/address.
#19 | |
#20 |
Thanks Dan for the Hood letter template! Wow only took minutes to make the holes! You should patent that bro!!!
#21 |
Perfect and dead on!
#22 |
Done! I'll be sending your template back first thing Monday bro! Dan for President!
#23 |
Wow. I was just thinking some poster board myself. Good job, and yes I would make and place for sale for others. Glad you got the job done.
#24 |
Yes it turned out perfect!
#25 |
did all 67-68 hoods have the chev letters on them? thanks, Larry
