10-27-2014, 11:38 PM | #1 |
Truck cutting out.
87 TBI 350, ran fine last time I drove it a month or so ago. Idles fine, revs fine, take it down the road and get in it some and it starts to cough spit and sputter, choke out.
I un hooked the egr ect, didn't do anything. A tune up has been on my to do list but I couldn't imagine lack of that would cause this kind of issue. Gas was fresh when I parked it and added some fresh yesterday. I have not messed with many of these TBI trucks so here I am. Best way to describe it would be like when your running out of gas and what little bit is left is sloshing around. Throttle body gunked up? Some junk broke loose and clogged the fuel filter maybe? Just thought I'd ask before I start tearing into this thing. Thanks fellas. |
10-27-2014, 11:46 PM | #2 |
Re: Truck cutting out.
Check your ignition as I am having similar issues and kept trying to adjust the carb. Now I need to replace my hei. Mine is old so it makes sense, but the coil has a internal short.
10-27-2014, 11:51 PM | #3 |
Are you referring to the pick up coil in the dizzy?
10-28-2014, 09:05 AM | #4 |
The coil mostly as that is my problem.
10-28-2014, 09:46 AM | #5 |
Robert Olson Transport
the pickup coil in the distributor or the HEI Coil will do this... Ive had aftermarket HEIs do this right out of the box
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
10-28-2014, 11:16 AM | #6 |
I appreciate the input, always figured the coils took a complete dump not work hit or miss.
10-28-2014, 10:58 PM | #7 |
Had the same problem, the magnetic pickup inside the distributor is the problem, its rusted or has metal shavings that ground it out. I went to local junk yard and found a clean one for cheap and problem solved. check around the metal ring and the pickups.
10-28-2014, 11:24 PM | #8 | |
Step one for fuel injected always is check for codes.
10-28-2014, 11:40 PM | #9 |
Ill pull the cap off tomorrow and take a peek, thanks.
10-29-2014, 12:21 AM | #10 | |
You won't find any codes under there.
10-29-2014, 08:52 AM | #11 |
Well im not gonna chance driving across town to see if there's any codes. My luck it will take a dump either there or back before I got it home.
10-29-2014, 01:29 PM | #12 | |
Why would you have to drive across town? You don't have a paperclip or small piece of wire to check the codes?
10-29-2014, 01:41 PM | #13 |
you mentioned the truck acts like it is running out of gas. maybe the truck is running out of gas? when was the last time the fuel pump and fuel filter were done. I believe 87 was the first year for electric fuel pump in the tank. do the filter also. the distributors are also a chronic mode of failure for 87. i would be doing the fuel pump and filter first then if you still have issues throw in a new distributor if you have too.
10-29-2014, 02:45 PM | #14 | |
You can watch the injector spray to see if the fuel dies down.
11-02-2014, 06:07 PM | #15 |
My buddy had a old coil laying around that we knew was good. For the hell of it swapped that out and crossed my fingers. All be damn it worked, runs good again.
