Old 10-28-2014, 12:04 PM   #1
Jahloha
Jahloha's Avatar
Rear Coil Bolt Removal?
Can someone provide me some hints on how to get the bottom bolt out of the rear coils on my 70' C20?
I removed the top bolts, but I cannot for the life of me budge the bottoms. They dont look rusted, but my HF electric impact wrench won't even budge the bolt from the bottom.
Thoughts?
Trying to get the last bits and pieces removed for sandblasting on Thursday.
Thanks!
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 10-28-2014, 12:14 PM   #2
Userone
Userone's Avatar
Re: Rear Coil Bolt Removal?
should come off just like the top bolt. I had to cut my coils off with a grinder so I could get enough room to grab the bolt inside the spring with a wrench. you might be able to cut the bolt off and hit it though with a punch and hammer.
Userone is offline   Reply With Quote
Old 10-28-2014, 12:40 PM   #3
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
My coil bolts were rusted solid to the arms. I got the nut off the bolt but had to heat the outside of the arm so as to get the bolt to spin. I hammered the bolt out after it spun. FYI, in the end, my arms were rusted paper thin & I had to eventually replace them.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 10-28-2014, 12:52 PM   #4
ChopperDr
Breaker bar. A long one. Let the bolt soak in PB Blaster for a day first. It will either snap the bolt or get it moving. Sometimes the ratings on inexpensive tools are over rated.
Chop
ChopperDr is offline   Reply With Quote
Old 10-28-2014, 01:11 PM   #5
Pick
Pick's Avatar
Don't be too shocked if it ends up coming apart like this:
1968 SWB Stepside "Bella coming home" "Bella's Build Thread"
A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack
Pick is offline   Reply With Quote
Old 10-29-2014, 12:02 AM   #6
Jahloha
Jahloha's Avatar
So update:
I tore down my frame and pulled the rear end off. Every bolt is loose or removed, even the U bolts....all except the two bottom side bolts for the coils!!
Here are some pics. I got to get these out, its killing me!
I tried to cut to bolt head off and push it through, but no freaking luck!!!
Name:  Bolt cut off.jpg
Driver side soaking
Name:  Bottom coil bolt.jpg
-JASON
Old 10-28-2014, 01:06 PM   #7
07travis
07travis's Avatar
My coil bolts were stuck in the arms also. I've been told this is pretty common on them. I soaked mine with PB blaster for a few hours, heated my trailing arms, then hit them with my cordless impact and they spun right out.
07travis is offline   Reply With Quote
Old 10-29-2014, 10:55 PM   #8
Tango59
Mine came off the same way.... hammerdrill and breaker bar snapped um. I should bought the bolt kit the same time I bought the springs and shocks
Tango59 is offline   Reply With Quote
Old 10-30-2014, 10:27 AM   #9
bollybib
bollybib's Avatar
There is a short description in this post of what I ended up doing to get my lower bolts out.
http://67-72chevytrucks.com/vboard/s...9&postcount=52
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 10-30-2014, 07:49 PM   #10
michael bustamante
michael bustamante's Avatar
Do you have a compressor and an airhammer? Drop thcoils and arms a little bit and wedge the lower coil cup away from the arm. This might lift the bolt out of the arm after you cut the bolt heads off
1967custom
michael bustamante is offline   Reply With Quote
