![]() Join Date: Oct 2013
What radiator are you guys running?
I'm putting a carb'd 4.8 in my 71 gmc (6 banger, auto) and was wondering what direct-fit radiator you guys might be using during your swaps.
I've looked at Be Cool, etc. but just wanted to get an idea of what;s working for you. I'm sticking with a th350 or 700r4 tranny by the way.
- Robbie UNITED BY TRUCKS - classic truck video content YouTube: www.youtube.com/c/unitedbytrucks Instagram: @united_by_trucks Paw Paw '68 508 Dark Blue Custom C10 Teddy '68 GMC SWB 503 Light Green LS Build Mississippi Mud '75 Skyline Blue Patina SBC Build |
Re: What radiator are you guys running?
Stock one will work fine. No need to swap it out unless you like spending $ or yours has issues.
Just make sure your system holds pressure, I read on here that if it don't your water pump will leak, mine did after using my stock old raditor
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck ![]() My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
Truck and auto performance nut
running a newish stock 4 core
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Thanks, guys. Very helpful info. Might just upgrade to a stock type 4 core.
![]() Join Date: Dec 2011
we make a bolt-in radiator for your truck here in the USA. We are also a forum sponsor and offer a discount to members.
http://67-72chevytrucks.com/vboard/s...d.php?t=590670 |
#7 | |
Cool, would be glad to help. Make sure to mention you found us here for the discount when ordering.
Sure will! Thanks.
Fabricate till you "puke"
4 row copper /brass, 2 14" elect fans ,on a steel shelf....wax on 205/off 195? Painless controls & relay set it off.... no fight
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
meowMEOWmeowMEOW
I just used a regular 'ol Be-Cool sbc radiator, seems to work great since I don't have a/c, and my trans cooling has its own seperate radiator.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
I've got a 4-core I pulled out of a BB truck I'm planning on using. Also going to be running an electric fan.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
I'm running the same 4 core that has been in it since my old man put it in when he was overheating while pulling a horse trailer with the original straight six. My 5.3L ALWAYS runs cool, and I'm still running stock clutch fan.
griffin for an ls-swapped '69 camaro.
had to tape a 16x16 chunk of coroplast to it today. it's been ~30 degrees and the truck took 30 mins to get into closed loop ![]() |
#15 |
Thanks for the replies, guys. I'm planning to go with RnD bc they have a great reputation and are less than 20 minutes away from me.
