10-31-2014, 01:41 PM | #1 |
68 GMC Stepside Axle
Hi everyone. I'm new here so bare with me if this topic has already been discussed. I have a 68 GMC Stepside that came with the 250 I-6 with the 3 on the tree. In the near future I am going to swap out that engine and trans for a SBC or BB but I'm not sure if the stock rear axle can handle the torque. So, my question is: What newer production vehicle with rear disc brakes will allow me to take it's axle and put it in my GMC? Thanks in advance.
10-31-2014, 01:45 PM | #2 |
Re: 68 GMC Stepside Axle
Do you have leaf suspension like most gmc's or coil springs? Are you wanting five lug or 6 lug?
1967custom |
10-31-2014, 01:49 PM | #3 |
I have leaf springs and I'd like to go with 5 lugs.
10-31-2014, 04:38 PM | #4 | |
10-31-2014, 08:11 PM | #5 |
Unless you are going for some crazy power the 12-bolt will be fine. They've run these trucks all these years with everything from a 250 to 454s and 6.2 diesels. You'll be fine. gMC did put Dana 60s in some 1/2 tons,but those were back in the 6-lug days. A Lincoln 9" rear with disc brakes is a hot swap. Those have 5 on 5 pattern. I want to say two more things. One is welcome to the board! the other is, now that you have a GMC and you're on the most informed GM truck site on the internet, you need to get sed to calling your truck a Fenderside. That's what GMC called them. Chevys are Stepsides.
10-31-2014, 08:28 PM | #6 |
I never knew that Special-K
10-31-2014, 09:00 PM | #7 | |
I have seen GMC's with 6 lug diffs that had 10 bolts on the cover. I wonder if that could have been a Dana? |
11-01-2014, 12:17 AM | #8 | |
10-31-2014, 08:49 PM | #9 |
Truck and auto performance nut
my '68 GMC w/305 V6 and 3OTT had a Dana44 when I got it. Not sure....but thought it to be original.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
10-31-2014, 09:04 PM | #10 |
Special-K, thanks for the info - I didn't know that either about the fenderside. I'm going to take a closer look tomorrow to see what axle I have but from some of the pics and info I found today that it might be a Dana 44.
11-01-2014, 03:17 AM | #11 |
Dana 44's are not uncommon in GMC 1500's in '67 and '68. A semi-floating 6 stud Dana 60 was an option, but is fairly rare. Full floating 8 stud 60's are very common in GMC 2500's. Remember that for the most part, GMC used Dana-Spicer and Chevy used Eaton/Corporate axles in '67 and '68, but there are exceptions.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
11-01-2014, 05:33 AM | #12 |
Yeah, I forgot to mention Dana 44s, but the Dana 60 would be the brute bolt-in...if you found one. I have built trucks (pro-street) using custom built Mark Williams Dana 60 5-lug. Ain't cheap! I forget what year Lincolns had that rear, but I know of people using them in the early-90s, so back around then and into the '80s. Probably the first years they put disc brakes on.
11-01-2014, 03:11 PM | #13 |
Thanks for the info i dont know what i will go with yet wish there was more info on the dana 44 .
11-01-2014, 11:16 PM | #14 |
The Dana 44 is a very common rear axle, just not in GM trucks! Check some of the Jeep and other off-road forums.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. Last edited by Bob B.; 11-01-2014 at 11:23 PM. |
11-02-2014, 12:14 AM | #15 |
Ive looked all over and cant find info about strength of the unit and how they hold up.
11-02-2014, 04:40 AM | #16 | |
Never saw one die, but they whined in pain a lot (my pain!) LOL. Gear whine, seems like way too many of them. New gears didn't fix them, they had to have the backlash re-set mostly and a few needed the pinion depth re-set. Re-setting the backlash was difficult, the shims are behind the bearings where they are pressed onto the carrier, unlike "normal" diffs where the shims are behind the bearing cups. The dealership was small time so they didn't have the tools that were shown in the shop manual for pulling the bearings so I had to cut the bearings and replace them every time I made a ring gear endplay adjustment. So, they help up good from what I saw in my limited experience, and I've always heard they are good. I'm just one who hates to work on them LOL Back in 67-68 I believe people were a lot more tolerant of a little gear whine so it would be interesting to me if the old ones whined and if it was considered normal. |
11-02-2014, 06:34 AM | #17 |
Wow thats messed up!lol Im thinking ill go with a dana 60 or a 9 inch ford
11-02-2014, 11:47 AM | #18 | |
Also, a differential comes apart much quicker when abused with a manual shifted trans than an automatic trans because a torque converter is much more forgiving than a clutch. Didn't mean to scare you, I just don't like working on them. |
11-02-2014, 07:09 AM | #19 |
The Dana 44 was used in the front of virtually all American 1/2-3/4t 4wd trucks as well as Jeeps, Broncos, and Scouts (& in rears) for many many years. GM started using 10-bolts by around 1980 and the general opinion is they are about equal in strength. Some parts are even interchangeable. 10-bolt to 12-bolt has it's differences, yet they seem to perform fairly equally. I'd say run whatever you have and if it doesn't hold up start looking into a beefier rear, or beef up the 12-bolt. 12-bolts and Dana 44s took the power from a BBC and put it to the road for many decades.
11-02-2014, 09:37 AM | #20 |
Welcome to the Best GMC Forum.
11-03-2014, 09:17 AM | #21 |
www.markwilliams.com
9" rears are good rears, that's what that Lincoln rear is. I wouldn't tell you what to do, but I would like to give you a place to look at all your options. I just like the idea of running a rear that cold at least be found in another GM, if not my model. The Dana 60 in a car or 1/2t pickup is a badass unit! Figure the hottest Mopars used the Dana60, a special few of these 1500s, all 2500s, some C/20, Ford F250s and Dodge D/W200s.
11-04-2014, 10:03 AM | #22 |
I took a good look at it this weekend and the axle has 44-I stamped on the bottom right side so I do believe I have a Dana 44. So, I have a Dana 44 rear with 6 lugs and leaf springs. Does anyone know if they will hold up to around 475 lbs torque?
I just bought this new toy 3 weeks ago and it is making me a very happy camper right now but the changes I have planned will be awesome. What do ya'll think of her? |
11-04-2014, 04:49 PM | #23 | |
11-04-2014, 04:54 PM | #24 |
Forgot to upload the pics...
Dan |
11-04-2014, 07:58 PM | #25 | |
