60-66 lift springs
im having a hard time finding a lift kit for a k10 suburban and was wondering if a lift kit for a 73-87 will fit. Thanks
Re: 60-66 lift springs
You might get answers faster if you post this in the 4x4 section. Specify yr BURB you have.
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
![]() Join Date: Aug 2008
There are no lift springs specifically for a 60-66. Leafs from a 70-72 k10 are the same length, and are available in popular lifts. The difference will be the eye size and the bushing types. 66 uses all bronze bushing, and a threaded bolts on the front spring shackle. 72 uses standard rubber or poly bushings.
I converted to the newer type when I built mine.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! Last edited by argonaut; 07-11-2019 at 09:41 AM. |
60-66 Nut
When you go with either '70-'72 or '73-'87 lift springs, you will also have to change the spring hangers to accommodate the springs.
That's what I did on my 61. Worked just fine.
So does the 67-72 or 73-87 give the same amount of lift or do you need a 6 inch to gain 4 on a 60-66?
#8 | |
why won't they fit?
1964 ![]() 383 sbc stroker under vortec heads sm420 trans / t221 tcase / corp 10 front axle / corp 12 rear axle / 3.73 gears rolling on 33x12x15 tires on 6 lug rims. ![]() |
#9 | |
I don't believe the holes in the springs are the right size. That's why I used the springs hangers off of a square body 4x4 for the rear and my machinist buddy modified the original front hangers to accept the standard bolts to mount the front springs in my truck. |
thanks 62shortstep!
so you mean the later model spring setups have larger shaft diameter bolts, and non greasable??? why manufacturers wouldn't just build a bushing to fit our trucks rather than not sell their product at all, baffles me... or simply sell an undrilled bushing and let the user drill out the size needed...
