Drop Spindle question
I have a stock height 65 Suburban. 6 lug all the way around. I want to stay six lug, but want front disk. I have been scouting for 73-87 donor trucks to grab the control arms and spindles. But I also plan on getting drop spindles and springs. Here is my question. Is there a drawback to just ordering the "Conversion" spindles that bolt directly to my existing ball joints and tie rods? Then just buying rotors, calipers, brake lines at the parts store. I probably would have replaced the ones from a donor truck if I went that route. Except for rounding up small parts, ie washers and caliper bolts, wouldn't this route be cheaper since I plan on drop spindles anyways?
Re: Drop Spindle question
I never went to all the research on whether I could have saved a few dollars, just bought a kit from CPP, kit included everything including calipers, dust sheilds, bearings, calipers, spindles, and so on. It was worth it to me not have to be scrounging around for odd hardware that may not have been included when buying individual parts.
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
They used to offer drlpped spindle disc or drum kits with 6 lug. Ill try to find a link.
. . Edit Found them http://m.ebay.com/itm/330946117099?cmd=VIDESC&gxo=true Or Ecklers http://www.ecklerstrucks.com/chevy-t...1963-1970.html
GOD BLESS AMERICA! |
![]() Join Date: Aug 2004
you will also need to change the Master Cylinder!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
![]() Join Date: Jan 2011
I have done it on both my trucks using the donor route. I rebuilt the front components and swapped them in. I added drop springs and drop spindles, the rotors you have to get aftermarket to stay 6 lug. Summit racing had the best price and service. Gave me everything I needed and came out good.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
I did all the research i could take "MY HEAD WAS STARTING TO HURT"and i just went with mcgaughy 2.5 drop spindle kit with everything! Everything bolted right up no problems!!,and i dont know how but i got lucky with my original 6 lug steel wheels clearing the calipers!!!!!!!!!!And they came off my 61 gmc!!!
![]() Last edited by cori 64; 11-04-2014 at 07:57 PM. |
I used this kit from CPP... I bought the upgraded version about 4 yrs. ago and at that time they offered the master cylinder with the kit.. This kit is great.. You have the option to keep 6 lugs or convert to 5.. i converted and chose 2.5 drop spindles.
That is the kit I bought from CPP, I went 6 lug, and 2.5" spindles, ordered the booster/MC/prop valve separately as kit from CPP as well.
CPP runs a lot of specials on Ebay . Also if you have CPP part numbers order from Summit its free shipping if you spend $100. CPP wanted about $100 to ship drop spindle kit and power booster combo.
is there any real benefit of staying with 6 lug over converting to 5 lug?
or is it only wheel preference? |
I did a McGaughy drop spindle kit on my truck from Summit. They offer 5 and 6 lug, and you don't need to change the master cylinder if you don't want to! The McGaughy kit is made to work with wheels as small as 15" I believe, so clearance shouldn't be an issue with it either. It wasn't that bad on pricing, $649 shipped and that included my rear springs, so probably about $550 for the brake/spindle kit
Another one of those questions that have me wondering about stuff.
I have a standard front end with 6 lug and drums up front, after redoing my suspension with 2" drop all the way around, I am now thinking that I want the front end a bit lower still.......... See here: http://67-72chevytrucks.com/vboard/s...585901&page=24 So can I do it while keeping everything else in place without sacrificing ride quality and use ability?
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
Hey Rian! Not sure how I missed your build thread before, but I am subscribed now.
I can't answer the question, and someone may have the answer for you, but may I suggest that you contact CPP, or the like by email to see if their drop spindles will accept your drum spindles?
