Another Lowering Coil Question!
So I lowered my 68 C20 4" in the rear and 2" in the front due to the 4:10 rear end gears and keeping a 31" tall tire for better drive ability. I also put one size smaller tire on the front. Been thinking it's too much of a rake look. I guy on Craig'slist has brand new 1/2 ton 5" lowering coils for sale because he is going with air ride. Will the 1/2 ton springs work on my 3/4 ton and if so will they lower it the same or more? I got mine from Paul's and I thought it mattered between 1/2 or 3/4. Thanks!!!
1968 Custom Camper C/20, rebuilt original 327 with 350 hp., turbo 400 with shift kit, factory AC truck, original patina rust free paint from Oregon, 2/4 lowering springs + 1" blocks, GM 2500 8 bolt rally's with dually center caps with Firestone Destination 245/75-R16's. (My 50th birthday present from my wife!!!) |
![]() Join Date: Apr 2005
Re: Another Lowering Coil Question!
I wouldn't go with any more drop with the springs, just add in a 1" lowering block. That way you will retain your current ride quality.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Are the lowering block kits the same from 1/2 to 3/4? Thanks!!!
Should be the same.
Hart Rod, thanks for your super fast response!!! Lowering block it is!!!
