Old 11-08-2014, 07:39 PM   #1
IdahoMan
Plastic/Rubber fabrication
What pro/DIY methods and materials do you all use to repair/fabricate the non-metal plastic or rubber parts on our trucks?
Things like rubber tailgate bumper grommets, dash board bezel, wiper knobs, bumper impact strips, door panels, etc..
How to add-to/fabricate them.
Examples:
For instance, if I'd like to repair the broken/worn blinker-light arrow holes on the dashboard by adding melted plastic and shaping it.
Find out what the rubber tailgate bumpers are made of so I can I have the right material to form my own seal between a bed box and the frame.
Or the front bumper impact-strip: What is it made of (plastic obviously, but what kind)? I might be doing some modifications to the bumper (probably with a Dremel tool) and so the edge of the IS won't have the cut-out in the bumper to plug into. Is there a way to add more plastic to the IS in an attempt to create screw-sockets? That way I could screw through the bumper and into the IS.
Yeah, I'm rambling here. Just trying to figure this out.
Thanks.
IM
IdahoMan is offline   Reply With Quote
Old 11-09-2014, 01:18 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Plastic/Rubber fabrication
well i noticed recently the plastic used to form(wheelchair) foot rests and other things is like the cluster bezel plastic.
you can use a heat gun to shape it
the texture is closer to later years
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
