Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 11-09-2014, 04:52 AM   #1
Andy4639
Old member
Andy4639's Avatar
Question Question
I'm fixing to install 6 way electric seats /heated in my 71 truck.
My question:
I have the power cable run to the amp under my seat now. I was wondering if I could tie into this cable at the power block by the speakers and run the seats with no problems with the speakers.
I need a hot wire for the seat and since it's already back there I thought why not. What do you think guy's Good/Bad idea?
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-14-2014, 12:01 AM   #2
Cooper197
Cooper197's Avatar
Re: Question
I don't see why this would be terrible, but I suppose it could lead to having feedback or noise in your stereo that you wouldn't want. I ultimately opted to just run new wires back for mine.
Cooper197 is offline   Reply With Quote
Old 11-15-2014, 12:14 AM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: Question
After think about it more I think I will have to run new wiring. My plan is to have them shut off when the key switch is turned off so that being said I will have to put it on a switched wire. I also plan to run the ground through the seat belt buckle so if the truck is running and you unbuckle the seat belt it will shut off to.
Old 11-19-2014, 09:20 AM   #4
Andy4639
Old member
Andy4639's Avatar
Drivers side is in. I ran a switched hot and had to rethink the ground. It didn't work through the seat belt. The switch is for a buzzer so when it was buckled it was off when you unbuckled it came on. LOL... So I just have the normal ground right now.
Old 01-10-2015, 11:03 PM   #5
Cash3481
Loves all GMC trucks
Cash3481's Avatar
Re: Question
Andy,
After reading is I'm glad you decided to run a new wire separate for the seats. I am fairly certain you would hear the seat motor in the speakers when you operated the adjusters. It's like having you home computer plugged into the same plug as your paper shredder. If your listening to music, it shrieks the shredder sound through the speakers.
Good luck on the other side.
Mike
If your helping someone and expecting something in return... your doing business not kindness!
Cash3481 is offline   Reply With Quote
Old 02-18-2015, 03:31 AM   #6
Andy4639
Old member
Andy4639's Avatar
Cool Re: Question
Originally Posted by Cash3481 View Post
Andy,
Thanks I got them all sorted out and all works fine now!
Old 03-22-2015, 02:31 PM   #7
PAWS 72
PAWS 72's Avatar
Re: Question
What seats are you using? You've always had a nice truck.
PAWS 72 is offline   Reply With Quote
Old 03-24-2015, 07:33 AM   #8
Andy4639
Old member
Andy4639's Avatar
1999 Tahoe seats. Thanks!
