11-09-2014, 11:06 AM | #1 |
Shocks
Just tried to install Bell Tech Shocks and they would not fit. They were hitting the frame in the front.
What shocks are you running? I want something better then the KYB's that came with lowering kit. Thanks! Heath
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
11-09-2014, 12:11 PM | #2 |
Re: Shocks
Move the mounts to fit
11-10-2014, 12:48 AM | #3 |
Re: Shocks
How would recommend doing that? The frame is drilled and bent.
Im looking for shocks that would just bolt in. What is everyone running?
11-10-2014, 01:28 AM | #4 |
Re: Shocks
I using Bilsteins. My truck is sitting on the stock suspension.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
11-10-2014, 01:54 AM | #5 |
Old member
Re: Shocks
Are we talking about stock mounts.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-10-2014, 04:08 PM | #6 |
Re: Shocks
I used this shock mounts on the front.
http://www.brotherstrucks.com/prodin...number=FSR6372 I had the whole front clip off, so install was a breeze. |
11-10-2014, 04:16 PM | #7 |
Re: Shocks
same here
Figure out what you want--then figure out what you are willing to give up to get it. |
11-11-2014, 11:54 AM | #8 |
Re: Shocks
Hello Andy,
Yes, totally factory mounts. I even installed the BellTech stud that mounts to the frame. There is NO WAY you can mess this up. I'd like to think I'm pretty mechanically inclined. I called BellTech and they said, "If they don't fit try our Nitro Drop 2's they are not as fat". The shocks I got are almost as fat as a Coke can. There is no way unless that stud sticks out 2-3 inchs the it will work. Stumped!! Heath
