Old 11-09-2014, 05:28 PM   #1
rickywideglide
rickywideglide's Avatar
2 piece driveshaft install
trying to install hd driveshaft switching from light duty ,does the old mount that hangs down need to be removed ..is there a thread covering this
rickywideglide is offline   Reply With Quote
Old 11-09-2014, 11:01 PM   #2
'65 chevy lover
Re: 2 piece driveshaft install
Not sure if there is a thread covering this or not. But, one thing you will need to do to make your driveshaft live is to, convert the inline carrier bearing to the u-bolt style. Here is a link to a HD style offered by Captainfab.
http://www.67-72chevytrucks.com/vboa...d.php?t=620312 Here is another link covering driveshaft length and related info. Hope this helps. http://67-72chevytrucks.com/vboard/s...d.php?t=429352
'65 chevy lover is offline   Reply With Quote
Old 11-09-2014, 11:14 PM   #3
rickywideglide
sorry original post was kind of vague, i have the bracket from captfab, was trying to put driveshaft in, which is all together im guessing something needs to come apart to get front in to trans. and bearing and bracket bolted into crossmember
Old 11-10-2014, 01:24 AM   #4
Captainfab
60-66 Nut
Once you have the new carrier bearing bracket in place on the crossmember, install the front driveshaft. Then slide the rear driveshaft onto the splines, making sure to align the yokes/U-joints, and bolt it to the pinion yoke.
Old 11-10-2014, 07:29 PM   #5
rickywideglide
had to remove bracket that went around rubber part of carrier bearing then slide complete driveshaft through crossmember and into trans. bracket from captnfab fit perfect
Old 11-12-2014, 08:51 PM   #6
rickywideglide
still having some issues with driveshaft,i switched from light duty shaft to hd shaft, and also changed rear from 3/4 ton to half ton both from a 63,to get hd shaft on had to remove metal bracket around carrier bearing(horseshoe style)to get driveshaft in,bolted everything down . now when trying to install driveshaft to rear its to close,the second part of shaft im guessing is a slip yoke and its pushed all the way in. im thinking the shaft is to long,but why even if previous truck had different trans. that wouldnt effect length on rear any help would be much apprecated will post some pics if needed.wondering if i should go back to light duty shaft and change out ujoints... sorry for the essay..
Old 11-13-2014, 11:45 PM   #7
rickywideglide
http://67-72chevytrucks.com/vboard/s...d.php?t=641548
Old 11-24-2014, 08:12 PM   #8
rickywideglide
ended up replacing carrier bearing on light duty driveshaft that was orignally on truck,and installing conversion bearing to accept 1/2 ton yoke.
