11-09-2014, 09:33 PM | #1 |
odd things on my 87
Wondering if any of you (especially ones who own 87s) have the following odd/different things on their trucks. Well this is according to me.
First thing is the driver's door lock. The switch does not operate up/down. This one operates front/back. Second is it came from factory with no front sway arm. This is according to the original and second owner (father initially purchased truck). I'm the 3rd owner. Third is it has a factory lock for the spare tire. It's a locking cover that fits after the eyelet bolt. Sorry, don't have any pics at the moment but can take if needed. Thanks for the feedback/help. |
11-09-2014, 10:01 PM | #2 |
Re: odd things on my 87
11-09-2014, 10:03 PM | #3 |
18 Till I Die
My 87 the door lock switch is up down. Yours needs to be rotated, easy fix. Cant help with the rest..
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
11-09-2014, 10:07 PM | #4 |
Can't rotate it. The hole is rectangled. Looks like this is how it came from factory.
11-10-2014, 03:48 AM | #5 |
Is it a Mexican truck? There are some odd features from across the border and I noticed you are in a border town.
11-10-2014, 03:57 AM | #6 |
No, somebody turned a pair of non-power panels into power panels and in the process they cut the lock opening 90 degrees off.
The bezels are rectangular in shape and can only fit in one way. The factory panel cutout is slightly longer in the horizontal plane (and so is the bezel - when LOCK is at the top or bottom). Leave it like that anyway - gives the truck character. Street cred. |
11-10-2014, 08:21 AM | #7 |
a) Somebody screwed up on the door lock. Should be up/down.
b) The spare tire lock is a GM accessory. c) Front sway bar is optional. The person that ordered the truck did not choose RPO F59. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 11-10-2014 at 08:26 AM. |
11-10-2014, 09:40 AM | #8 | |
That is not a normal lock button. If it was installed as it is supposed to be then "lock" would be upside down. Looks like a normal button would fit there.
11-10-2014, 11:29 AM | #9 |
The truck is not a Mexican truck but does belong to a Mexican. lol
I did forget to say that the door lock switch is not square, it's rectangular. If I was to install it the "right" way (up/down), the switch would not even with the window switches as Sean's pictures show. I don't have a problem with the switch. Only thing I'm worried about is what I'm going to do when the switch ever decides to go out. I don't think I'll be able to find another that's the same. |
11-10-2014, 11:54 AM | #10 |
That switch bezel thing is bizarre. I didn't notice at first but, it is normal in every way except for the location of the "LOCK" marking.
Mr. badchevy's is on the righthand side border rather than on the bottom (like every other bezel I have seen): And even if were indexed so that LOCK was on the bottom rail, it still wouldn't be correct - the lettering would be upside down. The way it is printed, no matter which way you indexed it, you would still have to push up on the toggle switch to move it towards the LOCK position. Ha! That switch bezel might be worth big money - you know, like a rare misprinted stamp. Last edited by chengny; 11-10-2014 at 12:00 PM. |
11-10-2014, 01:58 PM | #11 | |
We have a saying here: "At Chevy, you don't make a mistake. You make a million of 'em". K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
11-10-2014, 03:23 PM | #12 |
Sorry, that was my idea of a joke. |
11-10-2014, 04:47 PM | #13 | |
This was my idea of a joke, too. K
11-10-2014, 05:36 PM | #14 |
I took the door panel off a while back and all looked normal. I have to take the door panel off again to replace the arm rest. I'll check for any markings on the switch and panel.
11-10-2014, 12:58 PM | #15 |
The door lock switch is likely from an 80's Pontiac, Buick or Chevy car. They had the lock word inscribed at the top of the switch.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
11-10-2014, 08:36 PM | #16 | |
Somebody just put in the wrong switch. While I can't think of which particular vehicles came with that switch I am familiar with the lock type it would be used for.
11-10-2014, 10:00 PM | #17 |
Only thing is the window switch would be a little closer to carpet trim piece/door handle. If the wrong switch was installed, then the panel had to be cut differently for placement of both switches. You can see this if you compare the placement of the switches in the pic I posted and you posted.
11-10-2014, 10:21 PM | #18 | |
They're both the same size, or at least look like the hole would be the same size. I can measure one if you want. Or I can measure the hole.
11-10-2014, 10:39 PM | #19 |
No need. I just went and compared my '82 and '87. The window switch is a tad bit farther forward than my 82 but nothing too drastic.
11-10-2014, 11:01 PM | #20 | |
That doesn't matter, it doesn't affect the lock switch. Putting in the correct one would make it look, well, correct.
11-11-2014, 11:47 AM | #21 |
78K & 79C Jimmys
Swapped parts to fit the 78 Jimmy
89 pass side (Burb PW/PL) 87 drivers (Burb MW/PL) yup mid 80s I'd say a Grand Prix?on the pull handle ledge,makes it Fwd/Back
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
