Rear end swap
I have a 72' step side with a leaf spring rear end and would like to convert over to coil spring. Does anyone know how to do this properly, got any pictures or links to go to help me out? What has to be added or removed, cross member for trailing arms, brake lines, etc.
Bill |
![]() Join Date: Jun 2013
Re: Rear end swap
I'm just now thinking of parting out my '67 stepped LWB and the trailing arms are in great shape.
I need to focus on my '54 3100.
Gale Gorman '54 3100 '67 C20 stepside |
#3 | |
The Older Generation
Re: Rear end swap
Hi Bill, You would have to get a trailing arm center crossmember, trailing arms, coil springs, track bar, and track bar frame bracket. The spring perches are different so you would have to cut your perches off and weld on the coil spring perches or swap rear axles. I'm probably missing something but some of the other guys will save me if I am..... Oh yes, I think the small crossmember behind the rear axle is different too. LockDoc
Re: Rear end swap
Lock Doc, Thanks for the info. I found a good set up in a wrecking yard with all the parts ( I think) to do the swap.
Should I be able to use my old brake lines. I would be changing the whole rear axle at the same time. |
#5 | |
Re: Rear end swap
I expect the lines would fit if it's a 71-72 5 lug rear end. |
![]() Join Date: Sep 2007
Re: Rear end swap
Shock mounts are different too arent they? ( uppers )
1967custom |
Re: Rear end swap
Re: Rear end swap
Thanks for all the help guys, but I think I will just go with 5" lowering leafs, sounds much easier and cheaper.
Bill |
#9 | |
Re: Rear end swap
Wise choice as far as I'm concerned... ![]() LockDoc
Re: Rear end swap
Not to hijack hotrod9454's thread but I see that your from Elk Grove, I use to live and work there for 8 yrs. anyways I'm also looking for some info as to how to do this on my 2wd converted blazer.
