![]() Join Date: Jan 2009
Ls intake lq9 6.0
I got my hands on a professional products Ls 2 intake and when I set it in place on the motor it does not seem to fit Do truck motors use different size intakes I have a2005 6.0 lq9
Pulatoy |
Re: Ls intake lq9 6.0
There are only two different intakes for those ls motors . The ls2 cathedral port and the ls3 rectangle port. Have the heads been change. Post a picture of the engine and intake.
meowMEOWmeowMEOW
There are more than 2 intake types, but your correct that there are only two port Styles. Rectangle port and Cathedral port.
What about it isn't fitting? Are the runners not lining up, or something else?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Fabricate till you "puke"
The coolant (steam lines), were not hitting on the bottom of the intake? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#5 | |
Boosted Member
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
meowMEOWmeowMEOW
Ya but doesn't the LS7 use a rectangle port also? You can put the LS7 intake onto an LS3. The runner design is made for higher cube cars, but I don't know if I'd say its another port type. It'll interchange, just not necessarily make the best power on a sub-400ci engine
#7 | |
#8 | |
Boosted Member
#9 | |
Left to right: CATHEDRAL RECTANGULAR LS7 |
I feel like a idiot about the fit but it was hitting a bracket on the rear and would not drop down so that problem is solved. Now another problem the heads are cathedral and the intake is a rectangle. The catalog says it is for a ls2 but I thought Ls2 heads are cathedral. Will this work. On the factory intake the top is not a full opening it is where the injector sit and in the aftermarket the injector is mounted above the rectangle in a hole of its own pointing into the top of the cathedral port so it looks like it should inject at the same hole.
Pulatoy |
#11 | |
No , It will not work . Not sure about the intake. Not familiar with professional products. If it is a rectangle it is for a l92/ls3. Ls2 is cathedral |
meowMEOWmeowMEOW
Interesting as I'm seeing more and more threads about builds boring out LS2 and LS6 blocks to about 4.1 so the valves aren't shrouded, and having it work. I'll have to qualify that these have all been custom blocks, so if there is a bolt pattern mismatch they might be handling it in the build (but I haven't seen mention of it).
Are all head with cathedral ports the same or are the truck motors Lq9 different cathedral then the non truck cathedral or are the heads identical
Pulatoy |
![]() Join Date: Apr 2005
I'm pretty sure all stock cathedral ports are the same.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#15 |
The new manifold ports are the same configuration and they match except on the manifold they are about1/2 inch shorter at the bottom
Pulatoy |
#16 |
That intake won't work. I'm curious as to why you didn't keep the truck intake?
They make way more torque. |
