Old 11-18-2014, 03:18 PM   #1
thelawdoc
What is the size of the bolt for the harmonic balancer?
Guys, I am in the process of changing out the timing gears on my '66 C10 250. The bolt is missing that fastens the harmonic balancer to the crank shaft. Anyone know the specs of this bolt? Thank you.
thelawdoc is offline   Reply With Quote
Old 11-18-2014, 04:25 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: What is the size of the bolt for the harmonic balancer?
This is an inline 6 (250), correct? They are not drilled and tapped for a bolt. The balancer is a press fit and nothing holds it on. You can drill and tap the crank. I did on my 250. Used 3 different drill sized to get to the needed tap size. You can use the same bolt as a SBC (IIRC 7/16" fine thread).
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-18-2014, 04:43 PM   #3
thelawdoc
Chevy Mike, Thanks! I was scratching my head on this one. I don't think I am going to start tapping the crank shaft. If it was good for 50 years, who am I to change it, lol.
