Old 11-18-2014, 08:14 PM   #1
ramsey
Door fit
Is anyone else having trouble fitting repro doors to original cab? Specifically the door jamb latch?
Almost like the doors are made wrong.......
ramsey is offline   Reply With Quote
Old 11-18-2014, 08:16 PM   #2
bowcoffin
Re: Door fit
You have tried moving the door jam around?
bowcoffin is offline   Reply With Quote
Old 11-18-2014, 08:17 PM   #3
bowcoffin
Re: Door fit
They used shims as well, it might do you some good to try and remove them and see if that helps at all?
Old 11-18-2014, 08:23 PM   #4
ramsey
Re: Door fit
I got them working. Required 5 shims per side. Then had to counter sink the bolts so they wouldn't rub the doors.
Has to be the door because I didn't change the cab.
These doors make me crazy!
Old 11-18-2014, 08:36 PM   #5
Grumpy old man
Grumpy old man's Avatar
Re: Door fit
You'll find the radius of the top rear edge of the glass channel of the reproduction doors does not match the radius of the factory cab door opening , Also they almost always need to be cut and re welded to fit and it's near impossible to correct the radius issue ,Will they work ? Sure are they the same as original ? No way ! Always try to find original parts when possible . the time spent repairing your old doors or good original replacements just may be worth it when possible .Reproduction does not mean perfect fit.
Old 11-18-2014, 08:38 PM   #6
ramsey
Re: Door fit
Don't I know it....a little too late
Old 11-18-2014, 10:07 PM   #7
Grumpy old man
Re: Door fit
many new owners (not you) tear their trucks down and toss the repairable rusty parts thinking the new shiny dent free reproductions are the way to save money on their rebuild and then get the bad news from their body shop of the countless hours needed to make their "new" parts come close to fitting . Most parts suppliers sell different parts with different stickers that come from the same manufacture ! Always look for repairable originals in my opinion !
Old 11-18-2014, 11:39 PM   #8
clemsonteg
Re: Door fit
Luck of the draw. I had one door fit really great and the other one not as well. I also found some crappy work on the drip rails which may be why the one side doesn't fit as well, but it's close enough for my driver
clemsonteg is offline   Reply With Quote
Old 11-19-2014, 02:46 AM   #9
adricar1
Re: Door fit
i also have replacement doors on the truck i have just bought. the drivers door fits ok, after moving and shimming. however the passenger door the gaps are too big between the fender and the rear of the cab. the doors measure the same each side, ?.more work is needed to get it acceptable at present, also the topof the door hoop as explained above is the wrong shape? Are the passenger doors worse than the drivers in the repo stuff?
GMC K1500 1971 350 cu in th350 4wd
Bondo Bob c 10 1971 stepside th 350
c10 1970 350 cu in manual air con stepside.
adricar1 is offline   Reply With Quote
