11-20-2014, 04:40 PM | #1 |
Scrapper 1
NO MORE SWAPING 3/4 to 1/2 ton front ends
I think i found a company that makes spindles for 1963-- 1970 that take the 3/4 ton ball joint and uses all of the stock Tie rod ends and Pittman arm and all the linkage for 258.12
Please call them on shipping. These are stock spindles Not lowing spindles But they do make lowering spindles All of you new guys that have 3/4 ton trucks your worries are over Now a 5 lug wheels are in sight. Now all you have to do is find a 1/2 ton Rear end change the rear springs and the front springs and you will have a 1/2 ton truck better gas mileage and you can put them Alum 5 lug rims on your ride. The guys using the rear coil Springs you will need to find a Coil spring 1/2 rear end But this is for the guys that have the Leaf spring Rear ends Part Number CP4S12 This is At CCP they Make front end parts for all trucks Comes with a Life time Warranty There in Calif phone number 1-888-522-8303 I talk to a guy named Mario They make them for the 2.5 drop spindles as well All of the Disc bakes from the 1971-72 will work on these spindles Now i know there will be a ton of you guys that will be transferring your 3/4 trucks to 1/2 ton with out having to swap front ends I remembered my Baha friend using some ones spindle that took the 3/4 ton ball joint and using it on a 1/2 ton spindle So all you guys swapping out your front ends that have no Alignment problems your worries are Over Give them a call they do ship as well |
11-20-2014, 05:15 PM | #2 |
Re: NO MORE SWAPING 3/4 to 1/2 ton front ends
POL has made those spindles for a long time.
The other option is to swap the lower control arm and tie rod end. Not a big deal. You could even use the 3/4 ton arms and weld in a ball joint cup from Speedway motors. It will run you like 40 bucks.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
11-20-2014, 09:18 PM | #3 |
Wooooooooooooooooosh = the sound of a sail deflating.
I was all excited reading the first post, then the rushing sound of wind hit the keyboard
GOD BLESS AMERICA! |
11-21-2014, 12:08 AM | #4 |
Hahaha I was right there with you.
11-20-2014, 09:23 PM | #5 |
CPP has also made that spindle for a good while. Nothing new. Most of the swapping gets done on the early trucks for the same reason we do the swap on the C10. Just really easy to do when doing the swap to power steering and brakes.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
11-20-2014, 11:21 PM | #6 |
67-72 parts collector,…
www.earlyclassic.com has had them for quite a while now also.
