11-22-2014, 10:00 PM | #1 |
95 C4 Vette suspension swap
About to buy a full front suspension set up from a 94 or 95 C4 Vette for the project truck. Has anyone here done this and what sort of headaches should I expect? There is a guy pretty local to me who does this to old trucks and has jigs to get everything where it needs to be. Ride height can be adjusted before its welded to the frame. Cradle and all replaces stock cradle. Rack and pinion, disks, calipers... every thing.
I was toying with doing the rear as well with the independent set up, but I believe Ill stick with the 4 link and maybe go a coil over set up. Not a fan of the bags... heres the set up.. http://pittsburgh.craigslist.org/pts/4727336114.html
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
11-22-2014, 11:04 PM | #2 |
Re: 95 C4 Vette suspension swap
The front you can buy a kit off http://www.flatout-engineering.com/products.html the rear your kinda on your own to make fit.
11-22-2014, 11:17 PM | #3 | |
11-23-2014, 10:01 AM | #4 | |
11-23-2014, 09:38 AM | #5 |
I'm curious what the benefits of such a swap are. Trying to learn something here, because these trucks already have independent suspension and, other than reliability and good looks, was for decades a reason these trucks were desirable. We started "clipping" old solid beam axle trucks with car suspension, obviously for a better ride. But,why is not so obvious for me here, that's all. It sounds cool and all, but isn't it a system built much lighter to carry a much lighter sports car? I understand many don't haul with their trucks. And, I know people autocross these trucks these days,too. But courses are smooth and don't present a lot of "shock" on the system
11-23-2014, 10:55 AM | #6 | |
Thats the reason Im doing it anyway.
11-23-2014, 02:12 PM | #7 | |
The main difference is in unsprung weight. That is, the weight of brakes, spindles, upper and lower control arms and the outer tie rods. The corvette pieces are aluminum, the truck pieces are steel. The lighter these pieces are, the quicker suspension responds and the lower the rebound forces are. That is, the springs do not have to work as hard to stop the upward motion of the wheel after hitting a bump and contact with the road after striking a bump is restored much more rapidly. That's the theory, at least. The difficulty with transplanting that suspension onto a truck chassis is the truck has a higher CG and a different roll center. The geometry of the corvette suspension is designed to work with the CG and spring rates in that car. Unless the suspension mounting points are moved and the corvette geometry maintained, this mod might not work well at all. The transplant can actually result in a loss of handling, not a gain; and it will empty your wallet very quickly if you have to pay to repair a hack job. Art Morrison has a chassis for our trucks with independent front and rear suspension intended for the Pro Touring circuit but it is not cheap. Performance never is! |
11-23-2014, 03:25 PM | #8 | |
11-23-2014, 03:47 PM | #9 | |
This guy specializes in mid 40s to mid 60s trucks and this will be the first 67 hes doing, so that would be my only concern. Doing it like this keeps all the geometry correct for alignment.
11-23-2014, 10:20 AM | #10 |
the boat guy
The rear looks pretty easy except the foreward mouns depending on desired ride height.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
11-23-2014, 01:05 PM | #11 |
What are his priced for the Dana 44 and Dana 36?
'67 GMC 2500, 292, 4spd, AC |
11-23-2014, 04:13 PM | #12 |
There is or was a build like this going on the follow my build forum on this site. The guy owns a machine shop and is doing all the work himself, I do not remember his name. You should go there and try to find him.
11-23-2014, 04:20 PM | #13 |
Actually most of the common aftermarket crossmember swaps (no Limit, Porterbuilt, Scotts Hotrods) essentially mimic the C5 suspension geometry, so I'm not sure what gain you'd get over one of those. They all use Mustang racks, all use much lighter tubular control arms. Also a 'Vette is about 6 inches narrower than one of these trucks.
11-23-2014, 05:06 PM | #14 | |
11-24-2014, 03:23 PM | #15 |
Longer rod ends for the steering I suppose, also the swaybar will not be usable if the track is radically increased. The Corvette will also be set up for much more positive offset in the wheels then a truck so you'll need to take that into consideration as well.
11-24-2014, 09:32 PM | #16 |
The 94 vettes has 13" x 3/4" rotors and the 95 has 13" X 1" rotors. Im going with the 95. Both are 62 and 1/4" wide hub face to hub face. Gonna pull my wheels and see what the truck is this weekend to get an idea of whats gonna need to be done as far as wheels go.
11-24-2014, 11:23 PM | #17 |
Thanks for the explanations. I guess the weights are closer than I thought.
