11-22-2014, 11:15 PM | #1 |
Expected rear end shift?
How much rear end shift can I expect when I air out? I will be installing a longer track bar and centering the rear end at ride height. I am a little concerned because it when I test fitted my rims this morning (20x8.5 5.5" bs) it looked like I only had around an inch between the inner wheel tub and the rim. I was going to run 255/40 tires all the way around, but that doesn't leave much room for the tires once aired out. I won't be slamming the truck on the ground, I'm not even installing a notch for now.
11-23-2014, 04:55 AM | #2 |
Re: Expected rear end shift?
You can figure it out with a piece of string and a pen on the ground. Just draw an arch using the same length of your panhard bar and measure the lateral change over the amount of drop you have.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
11-23-2014, 12:13 PM | #3 |
Thanks. I ran one numbers and it looks like it's 0.5-0.75" with around 6" of drop from ride height to aired out. I measured my rear end and I came up with about 57" from backing plate to backing plate. I thought that meant I had the wider rear end rear and I guess I expected more clearance between the wheel and the inner fender
11-23-2014, 10:58 PM | #4 |
I ran my extra long bar just slightly above parallel on the frame side. As it drops 6.5 inches the bar rests just under parallel and the tires are 1/8" difference from ride height. This pic makes the angle look more dramatic than iy really is....taken from the side. Looking straight on, it has a slight up hill climb.
GOD BLESS AMERICA! |
