Old 11-30-2014, 05:19 PM   #1
Puke160
427 tall deck in a 1979 K25 GMC
I'm in the process of rebuilding a 427 tall deck to put in my K25. I am trying to find out if I can*use the 13" clutch assembly and flywheel out of the C70. Also if there is a dual plane low rise intake for the tall decks, so I don't have to use the spacers. And will the radiator out of a 2 ton fit in my truck. Also header fitment. The truck will be used to pull a stock trailer and as a wood truck. So the setup should work good as long as everything fits.
Puke160 is offline   Reply With Quote
Old 11-30-2014, 08:41 PM   #2
mrolds88
Re: 427 tall deck in a 1979 K25 GMC
You can use the clutch, but you have to use the rest of the transmission stuff too. The 13" clutch uses a larger bellhousing, This requires the steel adapter ring and the MD bellhousing and the MD trans as the input shaft is bigger. It is a benefit for you though. Headers I cant help you with, ,nor the intake. One last thing, I seem to remember that the 5 speed overdrives from a military deuce and a half are supposed to bolt up to that bellhousing.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 12-01-2014, 03:00 PM   #3
bdiamond
Unless you set the engine really high I bet you'll be hard pressed to find a pair of headers that fit inside the frame rails.
bdiamond is offline   Reply With Quote
Old 12-01-2014, 04:06 PM   #4
Puke160
If I use the MD transmission then I can't use my 205 transfer case because of the output shaft. I don't know about the military 5 speed. The truck spends 90 percent of its life in dirt, mud, or snow. I need the 4 wheel drive. And hooker make a set of headers of a standard big block swap in this truck. I call them twice, jegs, and summit and everyone I talked to said they don't know if they would fit.
1949 Chevy C3100
1979 GMC K25
1982 Chevy C20
2000 Chevy K2500
2002 Pontiac Trans Am
Old 12-01-2014, 09:33 PM   #5
mrolds88
I totally missed the "K" part. Doh!!! You are right about the 5 speed. HOWEVER there may be an out for you. GM put SM465's in the big trucks with the 13" clutch. With that said, you may be able to simply swap the input shaft and be done. Or you may be able to swap output housing and output shaft onto the big truck 4 speed. That would do it for you.
93 K2500 xcab 6.5TD
Old 12-02-2014, 01:07 AM   #6
Puke160
The truck has a sm465 in it but I think it's a 12" clutch not the 13" but if they useed the sm465 in the medium duty trucks it should be a pretty easy swap. It's coming out along with the np205 to be rebuilt and beefed up some.
1949 Chevy C3100
1979 GMC K25
1982 Chevy C20
2000 Chevy K2500
Old 12-04-2014, 02:38 PM   #7
78maliburat
I have a tall deck 427 in a 85 and jegs brand headers fit nice no issues
78maliburat is offline   Reply With Quote
