454 Flat Cam Question?
Re: 454 Flat Cam Question?
Video not working for me.
Sounds like it is a distinct possibility with today's oils. If this happens to my 350 I am swapping in a 350 Vortec. Is the adjusting but further down then the others? |
Seems like several are down farther, a few even feel like they're bottoming out when I tighten them. Of course I don't leave it that way but all rocker arms are not the same adjustment.
How did you adjust them?
Running or shut down? |
I don't know if this is pertinent to your question, but early 454s were notorious for flat spots on the cams (i.e. "soft" cams.) My 73 454 got to the point where some pushrods snapped and that was cause for a new camshaft and some pushrods, etc. I don't see any particular anomalies in your video, especially for an old truck. I would just wait until your cam gives out and replace whatever breaks - unless your are driving 90 mph on the 101 everyday.
![]() Just curious, why are you doing a valve adjustment? |
#6 | |
Valves should NEVER be adjusted running.
What do you have for a cam and valve springs? What are you using for oil? |
Hydraulic lifters should never need a hot or running adjustment. If they come out of adjustment, then either the rocker nut need fixed or replaced, or you have a bad lifter that needs replaced, or a bent pushrod that needs replaced, or the cam lobes are wearing out. Once the surface is worn more than a few mils, your cam lobes will wear VERY quickly because the surface hardening is gone. My vote: Replace the cam, lifters, pushrods, and rockers before it kills the crank with the bits from the ground off lobes. Learned that one the hard way.
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
I was going to say that I thought adjusting these went out with solid lifters.
![]() I would note that when my 73 pushrods broke, I think I had a total of 2 broken pushrods and 1 or 2 bent rods. The cam was replaced along with the bad pushrods and it ran great after that. So, replacing the cam and all of the other parts as a preventive measure on an old truck which is not daily driver would not be my choice. I would roll the dice and hope that you have an experience like I had with my 73 - it just stopped moving while I was driving it in town and I pulled off into a parking lot, had it towed to a repair shop, and had about $400 in repairs. Once you crack open an old engine you never know what you will find. I have read many posts here that start out as a troubleshoot minor dissection which turns into major surgery. Sometimes it is cheaper not to know the whole story. A full rebuild on a 454, even doing your own labor, can be pricey, and it is easy to make a costly mistake. If you do go with a new cam, make sure you get the proper cam for your VIN and engine number - there is a difference between a truck cam and a car cam. One the other hand, just pulling out all of the pushrods to see what condition they are in won't cost much, even if you have to replace all of them, and it might give you and indication of the camshaft condition. |
Since when??? Weight/stall/gears and rest of the engine combo are all I've ever needed for a cam. Blocks are the same unless you get into the heavy duty or aftermarket stroker tall deck block.
#13 | |
I will try a non-running valve adjustment when I check to see if the push rods are bent, any idea of what they're supposed to be set at?
#15 |
I am not sure about truck vs. car cam on a 454, I just know that the first 454 cam I got was incorrect - was told by the mechanic that it was a "car" cam. I do know that some 454s had "RV" cams - maybe camper special like I had?
#16 |
The adjustment should be between 1/2 to 1 turn tight from zero lash at TDC for each Cylinder. Individual specs may vary from manufacturer but that would work with any stock or mild aftermarket cam and lifters.
#17 |
Have it checked for cracks and core shift, then send it to the machine shop if needed. If it's usable, heck of a score!
#18 |
x2 on the 454 deal. Regarding just your pushrod check, you can get a set of new pushrods cheap, if you do need them, so why disassemble another motor that you can probably sell for more than enough to cover repairs on your engine.
#19 |
#20 |
It's if the casting/machining was slightly off center. It would be that way since new for a given vehicle, not something that happens over time.
1973 C20, 350/350 |
