what's a good/loud glasspack?
hey guys, any recommendations on a good and super loud glasspack? I currently have some glasspacks from the PO but im looking for a louder or more of a hotrod sound.
Thanks! |
Re: what's a good/loud glasspack?
My brothers truck has Cherry bombs straight off the headers and is pretty darn loud. Although my truck has exhaust manifolds with straight pipe into Purple hornies that dump under the cab is louder.
Are you trying to run exhaust or just something loud that you can still drive? Both mine and my brothers trucks are loud at idle and loud when you put the pedal to the metal, at cruising speeds they quite down some |
Well right now i just have the headers running straight to dual glasspacks. Its loud idle and stepping on the gas but during crusing it is pretty quiet.
Borla mufflers are loud and give a deep rumble sound if you get the right ones. You could also get shorter glasspacks.
"Back in the day" before you ever put the glasspack on the car, you squirted lighter fluid on the inside of the muffler and lit her up. Burn out all the fiberglass then put it on the car. That way you effectively had a straight pipe, but when you got pulled over you could show the cop that you had a muffler.
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
#6 | |
72 GMC
fuel pump was still pumping. just before exiting the tunnell, we turned the key back on. that cleared out the muffler, too. if there was anything left of it with that loud explosion of a muffler full of raw fuel !
KEL Members I have met : 2014.02.01: bruceman1968, Mr Handy, colgad, RenoKeene, CaptRMW |
My old man used to get em super hot and then shut off the motor and put the water hose in the tail pipe and it would break up the fiber glass. Then he would just fire it up and blow out all the glass and water.
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding ![]() My build : 68 C10 Short Bed Conversion |
I understand the Moroso spiral flows are pretty loud, basically look like a glass pack but there is no actual packing in them, just what kind of looks like an auger inside.
#9 | |
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#10 | |
![]() Join Date: Sep 2010
![]() Join Date: Sep 2007
Pirple gorneys sound great on a old 350
1967custom |
I have dual Thrush mufflers with 2" pipe. Its not crazy loud, but it gives that nice low rumble. Similar to Flowmaster. It could be louder, but I wanted a 2 chamber muffler and 2" pipe to save HP when i get around to putting that new motor in.
I used lmcs glasspack kit, they are generic glasspacks and i have hedman longtubes, raps pretty good when you get on it... Set off a car alarm in town once too..
I've got the sweet talkin' purple hornies after headers on mine! Sounds fantastic. I have it set so that in gear idling at a light is around 600rpm and it just sounds great. plus it's fun when... you know
#15 |
![]() Join Date: May 2012
If you just want loud loud loud, get a small set of glass packs. Turn them around backwards will make them even louder.
#16 |
Got 3" Thrush (FlowMaster rip-offs) for $29.99 each we have em on 3 trucks, mines the loudest, exiting in front of the rear wheels, LOVE IT! Unless you LIKE the Burning Fire-flys effect flying out of your exhaust at night, under hard acceleration, these will probably last longer.
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" |
