Old 12-04-2014, 10:15 PM   #1
jlampka
250 Straight 6 Auto or Manual
I have a 1971 C20 Chevy pickup with a 350 V8 and an automatic transmission. I am thinking of pulling the 350 out and putting a 250 straight 6 in for better gas mileage. I have a line on a 250 engine from a 68 Nova that had a manual transmission. Are there any modifications I need to make to this engine or will it bolt on the auto transmission in my 1971 C20 truck?
jlampka is offline   Reply With Quote
Old 12-04-2014, 10:19 PM   #2
CST10
CST10's Avatar
Re: 250 Straight 6 Auto or Manual
Your gas milage will depend on the rear gear. I have a truck with a 462ci with turbo 350 tranny and 3.08 rear gear that gets 10 mpg and I have another trick with a 250ci with 3 speed manual and 3.73 rear gear, guess what it get 11-12 mpg. Not much better. And the 3.73 geared truck turns high RPM's on the highway.
I wouldn't change it out thinking I'd be getting a huge change in mpg.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 12-04-2014, 11:04 PM   #3
Wrenchbender Ret
It will bolt right up to your presant trans. I'm with CST. You would be better off putting a 700R4 trans. in it. Then drive it real slow & sluggish like you already have a 250 in it. You will get as good as or better mileage.
Wrenchbender Ret is offline   Reply With Quote
Old 12-05-2014, 06:32 AM   #4
18436572GMC
18436572GMC's Avatar
Or a 6.2 diesel.
Yes it will get better mileage
Yes it will be gutless above 40mph
But at least there will be something cool about it
Real trucks have a clutch. Please inform automakers.
1972 GMC, K25, 383 stroker, SM465, NP205, Eaton HO-72
18436572GMC is offline   Reply With Quote
Old 12-05-2014, 12:53 PM   #5
jlampka
So then the bolt pattern is the same as the 350 to my TH350 auto trans?
Old 12-05-2014, 12:30 PM   #6
LukeandI
LukeandI's Avatar
When I was in my 20s, I had a 65 c10 fleetside with a 250 and single downdraft rochester. I got 12-13mpg in the mountains, valleys ...pretty much everywhere I drove. Last year I picked up a 70k10 short box stepper with 350, 4" lift, 33s, and the same 373 dif and 4spd. I drove that over the Coquihalla (google it) in November and got dead on 16mpg. 250s are cool but no gas savings there...
LukeandI is offline   Reply With Quote
Old 12-05-2014, 12:40 PM   #7
cayce_brunswick-
I'm on board with everyone else. Over drive or a gear swap or even both. I have been really thinking about a 200r swap. But I have a line on one I can pickup almost free.
cayce_brunswick- is offline   Reply With Quote
Old 12-05-2014, 12:48 PM   #8
nascarguy320
nascarguy320's Avatar
I am installing a 700r4 with my 250 six.
nascarguy320 is offline   Reply With Quote
Old 12-05-2014, 01:05 PM   #9
nascarguy320
Yes it is.
Old 12-05-2014, 01:15 PM   #10
faribran
I have had both 6 cyl and "for-kid" eights in these trucks. There is no way I would go in this direction. The 6 cyls I had got less gas mileage and not nearly as much power.
faribran is offline   Reply With Quote
Old 12-05-2014, 01:19 PM   #11
nascarguy320
Well I had work done to my six so its at 400 horses now.
Old 12-05-2014, 08:21 PM   #12
R.L.
R.L.'s Avatar
I pulled the 700r4 out of my truck, I'm running a 250 and it never was in it's power band. I went to a 3 sp manual trans. Mine is stock, I'm sure if you get the HP up it will be fine but going to a 6 for MPG is not going to happen.
R.L. is offline   Reply With Quote
