12-07-2014, 09:39 PM | #1 |
Idea for spotting fake shortbeds
With probably more shortbeds out there now than were ever built, I think it will become increasingly difficult to confirm the value (ie: originality) of a shortbed.
Of course the SPID lists it, but its easily faked (not easy to do, but easy to have it done for you). I was thinking that most places I've lived list the vehicle wheelbase on the registration. So, if you're buying a shortbed, ask to see the oldest registration possible. I would wager that a lot of people do not update the vehicle registration info, and they obviously cannot do it retroactively. So, if you have a registration from 10 years ago that shows it at 115, you've got some good clues. If it shows a longbed and the guy has some lame explanation like "Oh, that's a mistake they made I never bothered to fix" or "They list them all with the same wheelbase", just run away. It's not a sure-fire test, of course, but just another heuristic to apply when verifying the originality of a shortbed. And remember, you can't trust photos. I'm a total noob with Photoshop and made this without a problem, so a pro could easily do it with a vintage photo. I'd also look for a "too smooth" area where the frame cut is typically done. An attempt to hide this will likely mean it's ground down, puttied, and painted. Original bare cast steel doesn't have that smooth sheen. Or at least I think they should be different. Any other good tips? I've been in a buying situation with a dealer where an X22 (RS/SS 396) had a fake cowl tag. The dealer played dumb, and may have been innocent. So keep in mind that just because the current owner can honestly tell you that he hasn't modified it, he can't know for sure what happened to it before he got it.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
12-08-2014, 12:34 AM | #2 |
Re: Idea for spotting fake shortbeds
Good idea.
Mine is a C20 Cab and front body. It's on an original shortbed frame and uses an aftermarket bed. My registration and title don't hint to anything about the size of the truck. (unless you can brake down the VIN) My SPID is the only thing with the wheel base, plus it's a camper special, which was C20 only I think. Of course, I don't have that badging anymore, only my CST badges on the doors. I like the idea of having my original glove box, color, and SPID....so I'm no looking to hide anything.
'68 C10 SWB '85 K30 Blazer |
12-08-2014, 03:24 AM | #3 |
Unless you are looking for a concourse condition all stock classic truck, I don't see how a long >>short conversion negatively effects the value of a custom truck?
I'm interested to hear what everyone's opinions are. |
12-08-2014, 04:30 AM | #4 |
Moderator
Look for the middle stake pockets on the bed. It's an obvious giveaway that the bed has been cut down. No paperwork needed, no SPID pic required. They are left behind 90% of the time. Even if the tops of the bedsides have been "filled in", the pockets will remain.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
12-08-2014, 08:21 AM | #5 |
You're cutting down the frame and box to make it a short bed, Does that makes it worth less? Then does cutting the frame to install C channels and removing springs for bags, widening tubs to make room for wider tires, customizing interior with different dashes, shaving doors, or any other heavy mods decrease value? I don't think so..
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. Last edited by hamjet; 12-08-2014 at 09:44 AM. |
12-08-2014, 12:43 PM | #6 | |
So, with resto-mods being in vogue at the moment, the "restored to factory original" might appeal to some but don't count on getting your money back when you sell. As for me, I like hot rods. Modified to the max, with a BIIIGGGG motor gets my blood flowing. A stocker simply won't do that. But, then, that is the difference between us in the truck hobby isn't it? |
12-08-2014, 09:08 AM | #7 |
How about a sticker that says " fake short bed".
I didn't realize people acutually cared. A nice well built rust free truck should be what a buyer is looking for. If you can't spot a cut down lwb does it really matter ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
12-08-2014, 10:54 AM | #8 |
Mine is cut down and I get lots of compliments and I tell them it's been cut down, professionally done by the previous owner who had the work done.
Although they did mess up on wheel base measurement and it's actually 2 in. shorter than a short box, hence the name shorter short box Ha Oh well still looks good and it's all about what the buyer once if your selling. Suppose a custom at this point ( which is just fine with me) as with the rest of the truck, tires, lift, interior, stereo, seat belts, soft ray glass, overflow tank, dash cluster, headers and exhaust, door and window knobs, custom door panels, sound deadener etc etc etc.... Just making it my personal style that I'm happy with.
1968 4x4 Frame, with a 67 Cab and Bed A Shorter Step 1999 Dodge 2500 Cummins Diesel |
12-08-2014, 11:02 AM | #9 | ||
If it is important to *you* as a buyer to have an original shortbed, then it would be very important to that buyer that the seller is up-front about this issue. And since shortening is happening more and more now, such a buyer had better know how to spot one, because not every seller will be up-front about it. There have been several cases aired on this very forum about buyers who *thought* they were buying an original shortbed, and found out later they had not. If it isn't that important to you as a buyer, I think you should still know about it before hand. That is one mod you need to have done correctly. Even if you don't care that it *was* done, you should indeed care *how* it was done. IMO, it is a mod in class all it's own. Most other mods don't compare in terms of potential consequences... So to me, it's all about knowledge before hand. At least then *everyone* knows what is being bought and sold, and all can decide for themselves if/what they're willing to give/take for it. This thread is one more tool to find out.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. |
12-08-2014, 11:16 AM | #10 |
If they've gone through the trouble of hiding the frame and cutting out/removing the stake pockets... a lot of people don't seem to know about this. ALL longbed and longhorn trucks have a CURVED radius in front of the rear wheel whereas on shortbeds, blazers, and suburbans the area is squared off in front of the rear fender.
Of course, this only holds true if the bed was cut down... they could always use an aftermarket bed or real shortbed sides. 1st pic is longbed with curve, second is shortbed squared off. Aside from high dollar restored CST's and Cheyennes... I really don't believe a cut down truck hurts the value much. I would question the work and inspect it thoroughly, and if done right, I would pay as much for a cut down truck as a "real" one. It definitely INCREASES the value of truck (that was once a longbed), as I think we could all agree that any shortbed, cut down or original is worth more than a longbed in the exact same condition.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 12-08-2014 at 11:48 AM. |
12-08-2014, 12:29 PM | #11 | |
Member #1049
I mostly agree with you, except for one item that I did not notice for many years, not all longbeds have the curve you mention, 1967 "only" longbeds are not curved in the lower front wheel well. |
12-08-2014, 01:00 PM | #12 | |
So I googled pics of 67 and 68 C10s looking for trucks with original looking paint... and yup, 67 long beds are straight and 68+'s are curved! It's crazy GM would make a design change like that. I could understand if they were like that from the beginning, but to change after one year? That requires new stamps, $$$,... I wonder what the reasoning was? So 45 years later we could discuss cut down longbeds?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
12-08-2014, 02:21 PM | #13 |
Keepin an eye out
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
12-08-2014, 02:38 PM | #14 | |
Member #1049
Funny thing that its only 68-72 long beds that have that curve, All shortbeds, 1967 longbeds, all Blazers and Suburbans do not. |
12-08-2014, 03:55 PM | #15 |
Thinking about it... I guess they had to remake/modify the stamps in 68 anyway for the federal turn signal requirement and made the change then... but again... as we've talked about, EVERY other model was "square" so why go to "round" for just the longbeds/longhorns?
12-13-2014, 11:18 PM | #16 |
So are the repop short bedsides squared off? Are the repop long bedsides curved? Seems like a lot of times the repop parts don't get the small detail right
12-09-2014, 05:24 PM | #17 |
I guess I should take a look at that since the drivers bed side is a 67, and the passenger bedside is a "who knows?" .... so the wheel well corners likely dont match
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding My build : 68 C10 Short Bed Conversion |
12-08-2014, 07:59 PM | #18 | |
12-08-2014, 10:38 PM | #19 |
I don't know about fake ones but here the real McCoy😜
12-09-2014, 05:56 AM | #20 |
See now that's just nice! But if it was a cut down frame I would swap the frame out asap! Just don't trust some peoples skills. I saw a real nice looking shortbed in the parking lot so I had to go check it out. Walking over I could see it had a body lift. When I got closer I could see the frame was cut and a big section was missing. The missing part was replaced with angle iron. one piece on the top and one on the bottom and a big air gap between them. And this boob was driving that death trap. I left a note on the windshield to get that junk off the road.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
12-09-2014, 08:18 AM | #21 |
Loves all GMC trucks
Lots of debate on here so far and many good points. Here's a question for everyone who says an original shortbeds are worth the same as cut down ones...
1. Do you also think an NOS hubcap is worth the same as a cap that was worked over to look new? 2. more importantly would you pay the same for it as a NOS one? I don't think any one is saying a persons beautifully restored truck isn't nice (we all love these trucks)... Remember, it's about the sellers honesty, quality of workmanship and the truck as an entire package. To me there is enough out there to find one and convert your frame just make sure there isn't anything wrong with the potential frame your moving over to. Sorry for the rambling...
Mike If your helping someone and expecting something in return... your doing business not kindness! |
12-08-2014, 12:34 PM | #22 |
Before I buy I put it on a lift. It's pretty hard to cover up the VIN stamped on the frame or the welds behind the cab where the frame was shortened.
If the vin on the frame is missing or does not match the VIN plate on the B pillar me and my money are gone. |
12-08-2014, 07:15 PM | #23 |
Has it been posted here that some frames do not have the vin stamped in them?
12-09-2014, 04:53 PM | #24 |
Florida Edition
My brother's 70 GMC shortbed Sierra Grande frame does not have any numbers stamped into it. Not on the front driver's frame rail or under the cab. Looks to be all original, just never stamped.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
12-08-2014, 02:52 PM | #25 |
The rear cab mounts would also most likely be bolted on rather than riveted in a conversion.
My 68 is an original shortbed, but I did cut down the 69 that I had. IMO an original SWB > cut down SWB > LWB in the same condition. This also assumes that the conversion is done properly. When I sold my conversion, I was up front with the buyer on the conversion. |
