Snowblower on a pickup truck?
So thought up a contraption while at work the pther day, snow blower mounted on the front of a pickup. Heres how i think i could make it work, simple, i think. Use the pto hole on a sm465 transmission and run a pto shaft to the front of the truck and run the shaft to a blower. I was thinking the blower could be take off of a tractor. For the up and down on the blower you could use an electric or hydraulic winch (also driven off the pto), and to control the chute you could have an electric motor with a worm gear to control where it blows the snow..
How does a transmission pto compare to a tractor pto in rpm, would a truck pto have enough speed to turn the blower? Or am i insane and scrap the whole idea... For the record i will probably never build this but.. Is it possible? |
Re: Snowblower on a pickup truck?
HHHmMMMmmm... Odd, but not impossible, But I think the reason most snowblower vehicles have a separate engine for the blower is why it would be difficult to run truck and snowblower. Your pto gearing would have to be incredible high I would imagine, remember, this is all just my 2 cents.
I figured a mildly built big block would have enough snot to run it... Maybe with the gear not so much? I dont know. Im basing that off of the fact that a 170hp tractor has no problem running a blower like that... Who knows
![]() Join Date: Sep 2010
How about a plow on a school bus ? . . . . |
I thought about this a year or two ago and did a little research. At that time there was one for sale on the Duluth, MN craigslist.
Start here: http://www.snowblowerguide.com/artic...ow_blowers.php
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
I should add, I stuck with my blade.
they make them here is one called The “Big Pigg” is a 72” or 84” wide self-contained two stage snow blower
http://www.google.com/url?sa=i&rct=j...18234691406021
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
I don't live where snow removal is necessary, but a big problem I see is that when you push in the clutch, the blower will stop. Seems to me you may be swapping gears some and that could be an issue. Also not sure where the PTO shaft will come out up front. May not be where you want it. I think if I was doing this, I would investigate a belt driven clutch pump and do it hydraulically. Then you could change to a winch and already be set up for it if you had a common mount setup. Or run a log splitter.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
With the PTO, wouldn't you run into problems with snowblower RPMs when you push the gas to make the truck move faster and let off the gas to slow down? Wouldn't the snowblower need a constant minimum RPM?
Shortbed club member
I remember seeing one on Ebay years ago.
It had a V8 in the bed to power the hydraulics, a cap covered the bed. The blower had two augers that were wider then the truck and at least 3 feet tall. The truck also had built in jacks on all four corners that would lift the whole truck off the ground. IIRC it was being sold by a small airport. this might be it http://www.yesterdaystruck.com/contents/tpic721.htm
71 custom/10 6.0/4L80E SWB ece 4/6 72 custom camper 350/3 spd 2020 Chevy Express 3500 2023 Hyundai Tuscon 1986 GMC 3500 Bucket Truck Sent from my Rotary Phone via 14.4kb/s modem. Last edited by Jack_71C10; 12-09-2014 at 05:26 PM. Reason: found a pic |
#11 | |
![]() Join Date: May 2013
I remember seeing it on ebay as well. Very cool truck. c20pickup,anything is possible. ![]() But is it feasible for you ?
Tom 71 K2500 71 K5 Jimmy |
![]() Join Date: Nov 2004
Seems like something the Red Green should would have built.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
