12-11-2014, 01:47 AM | #1 |
Drill Bits - What do you recommend?
I am at the end of my rope with Home Depot and Harbor Freight drill bits, they can't make holes worth a darn (in automotive metal). I have those gold ones, and they are terrible. What bits do you recommend, I think I will buy just one bit at a time as I need em, cause I know I don't use 80% of the set(s) I own. Or do I just need to sharpen the ones I got.
12-11-2014, 02:42 AM | #2 |
20' Daredevil (Ret)
Re: Drill Bits - What do you recommend?
Any good cobalt drill should be hard enough to do the trick. If what you have isn't working, sharpening them won't help much.... even if they are better, they will quickly lose their edge again. Dunno about Home Depot but I wouldn't trust Harbor Freight drills.
There's a company called Tough Technology Products that claims to make super hard cobalt drills. Might be worth checking out.... Google TTP drills.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
12-11-2014, 02:53 AM | #3 | |
http://www.ebay.com/itm/13-Pcs-Cobal...item5b09636d88 |
12-11-2014, 04:29 AM | #4 |
Designated Grumpy Old Man
Try Grainger.com or McMaster.com. Both carry better drill bits.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
12-11-2014, 06:53 AM | #5 |
blood type; Retumbo
I discovered cobalt bits a while back. Nothing else even comes close any more.
Go slow with the drill speed, bits will last longer. I've also got Drillmaster kit that handles up to 3/4" for sharpening them. Slicker than frog snot on an ice cube
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
12-11-2014, 11:49 AM | #6 |
ROFL, neva herd dat one before
12-11-2014, 08:58 AM | #7 |
Equal opportunity joke ofender
x2 on Mc Master Carr. www.mcmaster.com that's all I use for work. It also allows to be able to buy just the sizes I need without having to buy a set filled with sizes I never use.
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
12-11-2014, 09:39 AM | #8 |
I used the dewalt set with the pilot tips and loved them, till i tried to drill stainless with them. Looking for some new ones myself.
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
12-11-2014, 03:00 PM | #9 |
Mac tools, Matco, and snap on have all been good to me. Pricey, but quality
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
12-11-2014, 03:56 PM | #10 |
I have the irwin pilot point set from 1/16 up to 1/2 inch. I also have a similar set from Snap On both sets are covered for life against dulling and breaking. I paid around 125 for each set and I like the irwin set better because of the pilot points. Both cut great though. Cheap drill bits get you nowhere other than frustrated.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
12-11-2014, 05:32 PM | #11 |
Try a company that sells industrial supplys. Ask for M-42 (cobalt) drills...you can buy individual sizes...no need to buy a whole set with sizes you don't need. The "gold" plating is titanium nitrate....worth the extra money if you are drilling tough material. Definetly stay away from Harbor frieght drills...they are garbage !
12-11-2014, 05:39 PM | #12 |
Moderator
What are you trying to drill that is giving you problems? If you are drilling sheet metal, use a step drill bit.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
12-11-2014, 05:58 PM | #13 | |
or drill out stripped philips screws in the rocker cover molding strips, simple stuff like that |
12-12-2014, 01:25 PM | #14 |
True cobalt drills are intended for stainless and hardened alloy steels where heat is a factor in cutting. Cobalt drills are for severe duty meaning they have thick webs and small gullets. chip clearance will be more of a problem when using cobalt. unless drilling stainless or hardened alloys the cobalt drills are overkill. there is no advantage in drilling mild steel.
from experience if your speeds and feeds are not correct cobalt tends to chip easy. true cobalt drills with have a designation of m42. most imported cobalt drills are not true cobalt and are most likely found in the box stores. a GOOD set of HSS drills is all you should need. i would suggest msc, msmaster carr or travers |
01-01-2015, 10:24 AM | #15 | |
Alex. |
12-12-2014, 08:53 PM | #16 |
Not much from HF is worth having, particularly things made of good steep, like drill bits.
A name brand of bit from the home store should work. Drill w/ low RPM and shoot some lube in there. Yes, drilling the same hole multiple times to get to 5/16 shouldn't be needed. Look at the material removed as you drill. Smaller means too fast. In theory, the bit should cut coils of metal off after a bit. |
12-12-2014, 09:53 PM | #17 |
My Irwin bits with the pilot points will drill straight through a frame with one bit. I don't care if its a 1/4 inch or 1/2 inch hole I need one bit cuts right through.The pilot point bits eliminate the need to drill a pilot hole.
12-13-2014, 10:04 AM | #18 |
You can get good quality bits at about any hardware store. Just remember you get what you pay for. Personally I buy HSS (High Speed Steel) with 135 degree point. The most critical thing about drilling metal is the cutting fluid you use. It is there to cool and lube the bit, without proper cutting oil even the best bit will be junk in no time. They get hot and lose their edge and once over heated they are junk. WD-40 is not a cutting oil, 3in1 Oil works ok, but I really like Tap Magic Cutting Oil. Remember to stop and reapply oil if drilling and large or deep hole. Good luck.
12-13-2014, 12:07 PM | #19 | |
12-13-2014, 12:09 PM | #20 |
This is the type of advise I come for on this site, you guys don't realize how much I appreciate learning from you all! Thank you so much.
12-27-2014, 12:48 AM | #21 |
Wish I would have read this thread in the morning. I purchased a set of Dewalt Titanium drill bits. Did I just throw away my money?
12-27-2014, 01:39 PM | #22 | |
Also watch your speed, someone else pointed out to drill slowly to get long strands of metal and not tiny bits that look like your daughters glitter just trying to help, or return them and buy just one or two bits you know you need for this job that will drill through the safe door at Fort Knox |
12-27-2014, 02:09 PM | #23 |
I had to drill some stubborn bolts out of my K5 hatch. The first few went great. The third snapped my bit. I'll use your suggestions on speed and pressure. Gonna probably splurge and by some carbide HSS bits and have on hold till these give out. I purchased the Dewalt ones with a XMAS gift card.
On another note, what drill would you use for the job I described above. I have a Dewalt Hamner Drill and a Dewalt Impact Driver Drill. Last edited by Senorx; 12-27-2014 at 02:14 PM. |
12-27-2014, 03:04 PM | #24 | |
I may be wrong on my sizes, but I think you may want a 1/2 inch drill cause they spin at slower RPMs then their 3/8 ths counterparts, donno which bolts you are going after but if possible shoot some PB Blaster (pronounced "your best friend") on them and let them soak over night also I like to drill a pilot hole with a much smaller drill bit in the bolt first if at all possible, then you can use a special extractor bit, have you seen those, even the cheap ones from AutoZone are good for one use, and if you are like me there is always that one exhaust manifold bolt that breaks, lol so all you need is one bit http://www.homedepot.com/p/Vermont-A...g&gclsrc=aw.ds An old timer suggested I get reverse drill bits, ie ones that drill to the left so there may be a chance where they catch the stubborn bolt and actually unscrew it |
12-31-2014, 04:53 PM | #25 |
I don't think there are any carbide bits intended for hand drills. Carbide is relatively brittle.
HSS isn't a great material. It was better than what was around when it was introduced, but Cobalt bits are significantly better.
1973 C20, 350/350 |
