12-19-2014, 03:21 AM | #1 |
trip meter possible exchange?
Is it possible to use a 89-91 suburban cluster with the trip odometer in an 84 swb c10 with limited wiring (know how) or just swap the speedometer to the one with the trip meter. As always thanks in advance.
84 c10 swb 305
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
12-19-2014, 10:54 AM | #2 |
Re: trip meter possible exchange?
The trip meter in the Suburbans and crew cabs, is just a mechanical meter in the speedo housing. You can just swap the speedo over to your cluster, and make note of the mileage. I've seen many that do not work, because of the design, so check it out first.
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD |
12-19-2014, 11:42 AM | #3 |
Your 84 should be a cable driven speedo and the ones that are from 89-91 are an electric speedo that need an electronic signal from the transmission. They may not work.
12-19-2014, 12:43 PM | #4 |
So what's my best bet for a cable driven speedo with a trip meter for my '73 C20? It sure would be nice, especially if I can't get my gas gauge to work.
1973 C20, 350/350 |
12-19-2014, 01:48 PM | #5 |
You'll only be able to use the 89' speedo. The 90 and 91 are electric driven and the cluster is different too. You'll probably also need to grab a new clear lense from the 89' to allow for the trip dial to come out for access.
Just be sure you get a good speedo that works. A lot of the trip speedo's get jammed up and don't work very well. If you are hitting a junkyard, bring a cordless drill to attach to the speedo cable to make sure everything works properly.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
12-19-2014, 09:44 PM | #6 | |
Cameron 1984 Chevy C20 Custom Deluxe |
12-20-2014, 09:07 AM | #7 |
I wouldn't see any problem with the 88 either. A few subtle differences like trip odometer and the high beam being one hole instead of two holes. Otherwise, I would think they would be compatible as long at they are driven by speedo cable.
12-20-2014, 01:05 PM | #8 |
electric speedo didn't start until mid-90. my 88 had the trip meter factory. just need the speedo itself, and the plastic cover with the reset hole in it. I have two extras as Mine was hard to reset, and found two different ones before I got a nice working one. I don't let anyone else reset it as they are kinda fragile.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
12-23-2014, 01:32 PM | #9 |
78K & 79C Jimmys
yup my 88 did too
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
