![]() Join Date: Mar 2011
Fuel tank vent check valve
any help with a part number on a simple check valve i just want to run something up the frame rail not all the way back to a canister or to a canister at all thoughts & advice
thanks in advance jz
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
![]() Join Date: Jun 2014
Re: Fuel tank vent check valve
if this is a stock location gas tank in the cab and you are using the original high loop by the passenger door no check valve is needed
#4 | |
