12-20-2014, 11:46 PM | #1 |
4 spd on the floor in a 66 C10 popping out of gear
2nd gear in my 4 spd transmission is popping out of gear. It happens during acceleration from a stop or when I am just cruising at low speed at light throttle. This is a 4 spd with granny low. Numbering the granny low gear as 1st gear it is 2nd gear that is causing me problems. I can hold it in gear if I hold down on the shifter but that doesn't always work. Local trans shop told me he thought it was the bearings and quoted me 650 bucks to fix if I pulled the trans out and took it to him.
Like most people with this trans I usually start from a stop in second gear, not really using granny gear unless I need to go really really slow... Anyone have any ideas as to what is wrong? Is it the bearings? Anyone have a spare 4 spd in Oregon they are willing to part with? Any help would be appreciated... Thanks! |
12-21-2014, 01:22 AM | #2 |
60-66 Nut
Re: 4 spd on the floor in a 66 C10 popping out of gear
I'm not in Oregon but I have a SM420 you could have. If you changed the bellhousing to a '68-'72 bellhousing, you could also go with a SM465. Those are a bit easier to find since they used them from '68 up into the 90's.
12-21-2014, 01:32 AM | #3 |
Senior Enthusiast
You might want to take a look at the following thread for possible solutions:
http://www.pirate4x4.com/forum/gener...elp-badly.html
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
12-21-2014, 02:32 AM | #4 |
Thanks for the replies! I actually have a good friend traveling your way for Christmas, Captainfab. Are you going to be around in the next week or two? If you have a good SM420 I would greatly appreciate it. I'd love to have a working 2nd gear.
