12-21-2014, 01:42 PM | #1 |
rebuild three on the tree
is there a kit to rebuild a three on the tree.i try to be careful to shift the h pattern and be gentle but it gets stuck. i lubed it and it helped a little but it needs to work better. i read all the comments about the floor shifters having slop and shift problems. is there a really good floor shifter? the transmission is the full syncro model. thanks.
12-21-2014, 02:40 PM | #2 |
Re: rebuild three on the tree
Thttp://67-72chevytrucks.com/vboard/showthread.php?t=215307ry this link.
It shows how to adjust linkage. |
12-21-2014, 02:55 PM | #3 |
Sorry that last link did not work.
Do a search under, 3 Speed Manual Column Shifter Adjustment. Shows proper way to adjust. |
12-21-2014, 06:31 PM | #4 |
12-21-2014, 06:40 PM | #5 |
Watch out for your cornhole !
You can rebuild the linkage for cheap money too. The parts are available from the usual suspects. Last one I did, I got the parts from Classic Parts.
