What position on mounting plate should I use
Sorry this might be a stupid question. But what position should I be using in mounting the plate for my LSx swap. I ordered a mounting plate from Ebay. They had 3 options. I seen other that are adjustable with multiple mounting holes. I am trying to minimize having to move the engine around too much by getting an idea first.
This is a 2005 5.3 into a 71 c10 with air conditioner and power steering. Should I stick with stock locationg, 1/2 forward, or 1 3/4 forward. I am planning to use my stock radiator. |
Fabricate till you "puke"
Re: What position on mounting plate should I use
This ? comes up a lot....depending on stands/position, it is really hard to answer? I would do a test fit on the engine/trans, & see what works the best, for your fit
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
I mounted my engine in the stock location to keep everything simple and avoid issues with the shift linkage. There's plenty of room for firewall clearance; it could have been set back a bit without hitting the firewall.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
Thanks for the replies. Will try stock first to see.
My thought has always been that as long as you have enough clearance, you want the engine as far back as possible. It gets you a better weight distribution, leading to more traction and better handling. Maybe if you haul huge loads it could be a minor downside, but that's about it.
Farther back may be more difficult to work on, but an LS shouldn't need much work.
1973 C20, 350/350 |
meowMEOWmeowMEOW
Put it where it fits. The whole "front to back" argument is tossed around, but most folks completely forget that train of thought when moving onto the rest of the build. I've seen people stress the engine position under the guise of weight balance, traction, whatever...and then never consider things like; weight loss anywhere else, actual suspension mods etc.
For 99% of the builds, just put it where it fits.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
![]() Join Date: Mar 2011
This is the best answer, each and every build is different....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#8 | |
#9 | |
meowMEOWmeowMEOW
I'm all for tubbing the firewall and setting that beatch into the cab 3", but since were' not building AFX cars, I'll leave that alone. lol my response is mostly to folks "worrying" about the wrong things. (lets face it, if we all KNEW we wanted racecars from the beginning, someone would be making GOOD fiberglass body panels for these things....but they dont ![]()
#10 | |
When I set mine in I installed the trans cross member bolt and set it down . That's where it stayed . This way I did not have to adjust the cross member and I used the existing drive shaft . Saved a few bucks and time . Everything else seemed to fall in place for me.
Spend a few bucks and get the adjustable plates so you can fit it where everything else fits best.
The other option is to read everyone's build threads and see which engine position you like the most and fits the accessories you have.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
